Simplifying a solution such that the imaginary number goes away
jwang34
Given a general solution to a system of differential equations:
Y(t)= C1(1;2i)e^(2it)+C2(1;-2i)e^(-2it)
side note: i is sqrt of -1, and the (1;2i) is a 2 by 1 matrix. The idea is to simplify the solution such that the imaginary components go away.
Euler's formula.
I have subbed the e^(2it) and e^(-2it) with their appropriate sin and cos counterparts. This is what I have have:
Y(t)= C1(1;2i)[cos(2t)+isin(2t)]+C2(1;-2i)[cos(2t)-isin(2t)]
and so from here, I lumped the cosines and sines together:
Y(t)=[C1(1;2i)+C2(1;-2i)]cos(2t)+i[C1(1;2i)+C2(1;-2i)]sin(2t)
I know I need to introduce two new free parameters to replace C1 and C2 but I'm not sure if I do that now or is there another way? I'm especially stumped as how to rid of the i from the (1;2i) and (1;-2i). Any suggestions are welcome. thanks.
This is really just Y=C1*z+C2*conjugate(z) where z is a complex matrix. The condition for Y to be real is Y=conjugate(Y). Putting it all together, don't you just get C1=conjugate(C2)?
I'm not sure I totally understand. So you're saying I set C1=the conjugate of C2? Or should I do set C1=C2*conjugate(z)?
C1 and C2 are constants, right? I'm just saying if C1=(a+bi) then C2=(a-bi). a and b also constants. That will cancel all of the imaginary parts. You need to check this yourself. Shouldn't this:
be this:
Y(t)=[C1(1;2i)+C2(1;-2i)]cos(2t)+i[C1(1;2i)-C2(1;-2i)]sin(2t)
Yes, you are right. I think I understand it now. So I should set C1=(a+bi) and C2=(a-bi) and the complex matrices will be resolved. Thank you so much!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
