Understanding Lenz's Law for Simplification
Lenz's Law states that any induced current from an electromotive force (emf) opposes the change that caused it. This means that induced quantities like current, voltage, and torque will always act in the opposite direction to their original counterparts. For example, when a motor starts, it initially draws a large current, but as the rotor spins, induced emf reduces the net current draw. A practical demonstration involves moving a magnet towards a coil, where the induced current generates a magnetic field that opposes the magnet's field. Understanding Lenz's Law is crucial for grasping the principles of electromagnetism and energy conservation in electrical systems.
OJ-Hick
I am having great difficulty grasping the concept of Lenz's law. As far as I am unware it is derived as:
"any current driven by an induced e.m.f opposes the change causing it"
I do not really understand what this means - help would be greatly appreciated :)
The law of Lenz can be described as follows:
Induced quantities, such as current (mmf), voltage (emf), flux, & torque, are always oriented in a direction opposite to the original quantities.
A motor is started. It's current draw is large when at a standstill. Once the rotor spins, mmf/emf are induced into the stator. This induced current opposes the original current. Hence the net current draw decreases.
If I pedal a bicycle type generator under no load, and I control the speed to 300 rpm, for example. I then load the generator with 50 watts. The added load current has a magnetic field which produces a an additional torque. This torque counters my pedaling torque.
Otherwise, a motor or generator would create its own supply of energy. Induced quantities, electrical as well as mechanical, always act in the *opposite direction* to the corresponding original quantities.
Is this helpful?
Claude
This Law is often demonstrated by moving a magnet towards the end of a long coil of wire. (Solenoid)
The result is that an emf is generated/induced in the coil.
If a current is able to flow in the coil, it flows in such a direction that the magnetic field it generates opposes the one that produced it- the one due to the magnet.
In practical terms, if you moved a N pole of a magnet towards the end of the coil, the current generated at the end of the coil would produce a N pole there - the N pole would be opposing the one producing it. (Like poles repel)
If you Google Lenz's Law demo you will find a better explanation of this than is possible in words, using some animations. There's also some stuff on YouTube.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
