Finding Solutions for Simultaneous Equations with Transcendental Functions
In summary, in order to solve this problem, you need to take the natural log of both sides, and then use algebra to solve for the y value. The first equation has a y value of 2, and the second equation has a y value of 3.
ssj5harsh
45
I came across this question once somewhere and I can't seem to get anything:
[tex]x^y = 9 , y^x = 8[/tex]
Solve the simultaneous equations.
Expressing [itex]x = 9^{1/y}[/itex] and then substituting doesn't help much. I get an equation in one variable, but no direct answer.
Again, taking log on both sides doesn't give anything conclusive.
One answer (at least) is obviously (3,2). How can I solve it mathematically?
I hope someone can help me.
Try taking
[tex]\sqrt{x}[/tex] so you get rid of the y power, making the equation [tex]y^\sqrt{9}[/tex][tex] = 8[/tex]. You can work it out from there.
Of course, you could do [tex]x^\sqrt{8}[/tex][tex] = 9[/tex], but I wouldn't suggest it, seeing as you will get an approximate answer, versus an integer.
This is about logaritims...
There are 2 equations, and two unknown variables. This means that the equation is solveable by some type of method. We just have to find one. Some knowledge of logaritim and exponential rules comes in handy for this problem.
Taking the natural log of each side allows us to "bring down" any exponentials that may be there:
[tex]x^{(y)}\,=\,9^{(1)}[/tex]
[tex]y\,ln\,x\,=\,(1)\,ln\,9[/tex]
Now, divide both sides by natural log of x:
[tex]y\,=\,\frac{ln\,9}{ln\,x}[/tex]
The algebra is alittle more tricky on the second equation, but this is what I get after doing the same process as above:
[tex]y\,=\,2^{\frac{3}{x}}[/tex]
Also,
[tex]\frac{ln\,9}{ln\,x}\,=\,2^{\frac{3}{x}}[/tex]
Now, you can solve it using more algebra (which I did not do!) or just plug these equations into a TI-calculator and see where the graphs intersect or use the solver on the calculator(make sure you are using approximation and not exact) and find the x value where these two equations are equal.
Anyways, x = 3 and then plug that into one of the two equations that were graphed and you get y = 2. Hope this helps.
The second one solved...
[tex]y^{(x)}\,=\,8^{(1)}[/tex]
First, take ln (natural logarithim) of both sides.
[tex]ln\left(\,y^{(x)}\,\right)\,=\,ln\left(\,8^{(1)}\,\right)[/tex]
Now you can "bring down" any exponents:
[tex](x)\,ln(\,y\,)\,=\,(1)\,ln(\,8\,)[/tex]
Get y on one side only:
[tex]ln(\,y\,)\,=\,\frac{ln(\,8\,)}{x}[/tex]
Here's an algebra rule that comes in handy, making both sides the exponent of the number "e" (2.271828...) allows you to cancel any terms with [itex]e^{ln(anything)}[/itex]:
[tex]e^{ln(\,y\,)}\,=\,e^{\frac{ln(\,8\,)}{x}}[/tex]
Hence, [itex]e^{ln(anything)}\,=\,anything[/itex] (by "anything", i mean a variable or a constant):
[tex]y\,=\,e^{\frac{ln(\,8\,)}{x}[/tex]
Here is where I cheated and used the calculator to solve for y (But here's the algebra anyways):
[tex]e^{ln(\,8\,)\,=\,e^{ln[\,2^{(3)}\,]}[/tex]
Now, solving with the method's above:
[tex]x\,=\,3,\,\,\,\,\,y\,=\,2[/tex]
Double checking by plugging into original equations:
[tex](3)^{(2)}\,=\,9[/tex]
[tex](2)^{(3)}\,=\,8[/tex]
Thank you, VinnyCee. You didn't need to be so descriptive, but I was hoping to find the algabraical way of solving this problem. I don't have a TI-calculator, but I had earlier found the answer with this one:
http://www.coolmath.com/graphit/index.html
I also tried the Powertoy calculator which came with Windows XP, though I couldn't figure out how to use it to find the value.
Try taking
That would be correct if the first equation were [tex]x^2= 9[/tex] rather that [tex]x^y= 9[/tex].
Every time I try to give advice it's wrong:frown: . I think I'll just post questions here from now on. :frown:
Such transcendental equations cannot be solved analytically,but only numerically or through graph intersection.
Plot implicitely each equation & intersect the graphs.It has 2 solutions.
Daniel.
1. What are simultaneous equations?
Simultaneous equations are a set of two or more equations with multiple variables that are solved together to find the values of the variables that satisfy all of the equations at the same time.
2. How do you solve simultaneous equations?
There are multiple methods to solve simultaneous equations, including substitution, elimination, and graphing. These methods involve manipulating the equations to eliminate one variable and solve for the remaining variable.
3. What is the importance of simultaneous equations?
Simultaneous equations are important in various fields of science, such as physics, engineering, and economics. They allow us to model and solve real-world problems involving multiple variables and equations.
4. Can simultaneous equations have more than two variables?
Yes, simultaneous equations can have any number of variables, although they are typically limited to three or four variables to make them easier to solve.
5. What happens if a system of simultaneous equations has no solution?
If a system of simultaneous equations has no solution, it means that the equations are inconsistent and do not have a common solution. This can happen when the equations are contradictory or if there are not enough equations to solve for all the variables.
  • Precalculus Mathematics Homework Help
