Simultaneous events in different frames of reference
In the discussion, participants analyze the timing of light flashes in two different frames of reference, F and F', with F' moving at 0.8c. Observers in frame F see the flashes at 2 seconds, while in frame F', one flash occurs at t' = 2.667 seconds, and the other at t' = -2.667 seconds. The confusion arises regarding how the moving observer in F' perceives the flashes, particularly the time it takes for light to reach them. Calculations indicate that the additional time for light to travel to the observer is 3.333 seconds, leading to a total of 6 seconds for one flash and 0.666 seconds for the other. The discussion concludes with clarity on the timing of the flashes as perceived in both frames.
Kyrios
In frame F there are two lights on the x-axis at D and -D (D=0.6x10^9 m ) which flash simultaneously when t=0. There is another frame F' which moves at v=0.8c in standard configuration with F.
I need to work out when observers standing at the origin of both frame F and F' will see the light flashes, and also in frame F' if the speed is -0.8c instead.
x' = γ(x-vt)
ct' = γ(ct - \frac{vx}{c})
So I think for observers in frame F it will be 2 sec but I'm not sure how to work out when observers at the origin in frame F' will see the flashes. I've got the distance to both points in F' and the time the flashes take place in F' but I am not certain what to do with it.
If you've worked out this much, then it should be easy to find the time interval that it takes the light to travel from the location of a flash to the observer. What is the speed of light in F'?
It should be c, like in all reference frames. I'm just getting slightly confused by the fact that frame F' is moving. And by which flash the observer sees at what time.
The flashes occur at 2.666 seconds in frame F'. Do I need to work out distance that it's moved in this time, add it to the original distance D and then divide by c?
If so, I get this to be 6 seconds. But I'm not sure whether this is the same for both flashes of light or not.
Only one of the flashes occurs at time t' = +2.667 s in F'.
In F' one of the flashes occurs at time t' = 2.667 s. But the observer in F' won't see the flash until the light gets to her. So, you'll just need to find the additional time it takes the light to travel to the observer. Similarly for the other flash.
The other one should be at t' = -2.667s.
I'm doing 1x10^9 / 3x10^8 = 3.333 s
3.333 + 2.666 = 6 s.
And the other frame would be 3.333 - 2.666 = 0.666 s?
That looks good to me. [Edit: "other frame" -> "other flash"]
great, thanks for your help :)
