How Far Beyond the Fence Does the Ball Land?
A kid throws a ball at a 45° angle from a point 5 m away from a 4 m high fence, which the ball just grazes. The initial calculations for velocity and distance traveled beyond the fence are questioned, particularly the assumption of initial velocity being zero and the use of conservation of energy. It is suggested to apply ballistic equations instead, as the final velocity does not necessarily maintain a 45° angle. The correct approach involves using the vertical displacement equation and substituting time to solve for horizontal distance. Ultimately, the discussion emphasizes the need for accurate application of physics principles to determine how far the ball lands beyond the fence.
shane99a
A kid is 5 m from a fence that is 4 m high. He throws a ball at 45° from the horizontal which just grazes the fence. How far beyond the fence does the ball land? You may assume that the ball was thrown from the same level as the ground on the far side of the fence.
Here's how i did it and its probably wrong so i need help:
Vi = 0
θ = 45°
Vf = ?
0.5mv2 = mgh
v = √(2gh)
v = √(19.6*4)
Vf = 8.85 m/s
Vy = 8.85sin45 = 6.26 m/s = Vx
Dy = Vyt - 0.5at2
0 = 6.26t - 4.9t2
t = 1.28s
D = Vxt
D = (6.26)(1.28) = 11 m
Therefore the answer is (11 - 5) 6 m which is the distance the ball traveled beyond the fence.
It looks correct except for the height which I don't know if picking 4 was the right idea and would screw up my entire answer, so please someone help.
Your initial velocity is not 0 m/s since he originally threw the ball. Also, I wouldn't recommend using conservation of energy for this problem. I recommend using the ballistic equations. For example, there is no reason that your final velocity will be at a 45 degree angle with the horizontal.
Hi shane99a, welcome to PF.
Your calculation of v is wrong. It is not the velocity of the projection of the ball.
It is true only if 4 m is the maximum height. But in the problem it is not mentioned.
So you have to use the equation
Dy = vy*t - 1/2*g*t^2...(1)
Substitute t = x/vx and solve for vx. In the given problem x is given.
To find maximum range, put Dy = 0 in eq.(1) and solve for x.
