Singular Values & Linear Transformations
grawil
I'm struggling to grasp what should be a trivial property of singular value decomposition. Say that I have a linear transformation T that is non-singular (i.e. T^{-1} exists) and relates matrices A and B:
B = T A
or
A = T^{-1} B
What I would like to know is how the singular values of A and B are related?
A and B are both dimension (m x n), i.e. T is square (m x m). My thoughts are:
A = U_A \Lambda_A V_A^T
B = U_B \Lambda_B V_B^T
where U is (m x m), \Lambda is (m x n) and V is (n x n). Substitution gives
T A = U_B \Lambda_B V_B^T
T U_A \Lambda_A V_A^T = U_B \Lambda_B V_B^T
but I'm not sure where to go next. From the above, can I simply write:
T U_A = U_B
\Lambda_A = \Lambda_B
V_A = V_B
This implies the singular values are identical (with the caveat that T is non-singular) and that only the basis vectors of A are affected by the transformation... this is what I want to show but I'm unsure if I've actually succeeded with the above.
After a bit more thought... the above is only true if T is orthogonal/unitary. I still think it is possible to relate the singular values of A and TA for the slightly more general case where T is full-rank (i.e. non-singular) but I'm not entirely sure how. Obviously, if T is not of full rank then all bets are off.
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
