CKH said:
Can you explain in ordinary language what you mean by "a stationary spacetime".
First let me give a somewhat technical definition; then I'll try to unpack it.
The technical definition is that, in a stationary spacetime, you can find at least some worldlines along which the geometry of spacetime is not changing. This doesn't mean the geometry has to be unchanging along every worldline; but there must be some family of worldlines that meets the requirement. In a non-stationary spacetime, it is not possible to find any worldlines along which the geometry is not changing.
Now for some unpacking. The most important thing is to be able to think of spacetime as a geometric object, independently of any coordinates we might use to describe it; so, for example, when you ask...
CKH said:
When you refer to "a spacetime" are you referring to a particular coordinate system with 3 spatial and one temporal dimension?
...you are mixing up two things that it's important to keep separate. Spacetime is a geometric object with 3 spatial dimensions and one temporal dimension; but the same spacetime, the same geometric object, can be described by many different coordinate systems, just as the surface of the Earth, the same geometric object, can be described by many different coordinate systems. The geometry is described by invariants--things that are the same regardless of what coordinates you choose. For example, the radius of curvature of a 2-sphere (like the Earth's surface--or at least an idealized "Earth's surface" that is a perfect sphere) is such an invariant; it's the same regardless of what coordinates you use to describe the surface.
So when we say that, in a stationary spacetime, there are at least some worldlines along which the geometry is unchanged, what we mean is that, along such a worldline, all of the invariants that describe the geometry are unchanged. Since a worldline is just a curve in spacetime that describes a possible trajectory for a piece of ordinary matter, like you or me, that means that if you or I were to travel along that worldline, we could repeatedly measure, over time, all the invariants describing the geometry of spacetime--the spacetime equivalents of things like the radius of curvature of a 2-sphere--and find them unchanged.
In our universe, which is expanding, there is
no worldline that has this property--there is no trajectory that we, or anyone, can travel through spacetime that will allow us to repeatedly measure any invariants describing the geometry and find them unchanged. They will all change as time passes, along every worldline.
CKH said:
why is the universe a non-stationary spacetime (I suppose because it's expanding)?
Yes. Meaning, the fact that the universe is "expanding" is one way of expressing the fact that it's impossible to find any worldlines in the universe along which the geometry is not changing.
CKH said:
I have a feeling that you are going to tell me this is a wrong conception
It's not wrong, but it's limited, because you're still implicitly relying on some underlying Euclidean space in which the curved grid is embedded. To really understand GR, you have to be able to let go of that and think of curvature as something intrinsic to a geometric object. The best way I know of to do that is to think about how you would detect whether a geometric object was curved, if you were restricted to only making measurements within the object.
For example, suppose we live on an idealized, perfectly spherical Earth, and we want to prove that it is, in fact, a sphere, rather than a flat plane. But we are not allowed to "cheat" by using any phenomena external to the surface of the Earth (so, for example, we can't use Eratosthenes' method and measure the difference in angle of the noon Sun's rays at different locations). How could we do it? Here's one way: pick out two meridians of longitude that are nearby, and start at the point where they intersect the equator. Notice that they both intersect the equator at right angles: that is, they are parallel at the equator. Then follow them north, and notice that they don't stay parallel: they get closer and closer together, until at the North Pole, they intersect.
What does this tell us? The key is that meridians, and the equator, are great circles, and great circles are the analogues, on a 2-sphere, of straight lines on a flat plane. The general term for curves that are the analogues of straight lines is "geodesics"; and if you actually look at the axioms of Euclidean geometry, you will see that the term "straight line" can be generalized to "geodesic", and the same axioms--with one exception--will be applicable to the intrinsic geometry of a curved surface, like a 2-sphere. The one exception is the parallel postulate, which (at least in one version) says that, on a flat plane, a pair of straight lines that are parallel anywhere (as shown by their both intersecting a third straight line at right angles) are parallel everywhere. On a curved surface, this no longer holds, as the meridians above illustrate.
We can detect curvature of 4-D spacetime the same way; all we need is to find out what are the analogues of straight lines--the geodesics. It turns out that, at least in the timelike direction, these are the worldlines of freely falling objects--objects which are weightless, feeling no force. (Sometimes we say that are moving "solely due to the force of gravity", but saying it that way can be misleading; it's better, IMO, to focus on the fact that they feel no force and are weightless, since that's the direct observable.) So to see whether spacetime is flat or curved, we simply pick two nearby geodesics--two worldlines of nearby freely falling objects--that are parallel at some point--i.e., the objects are at rest relative to each other at some instant of time--and see whether they stay parallel--i.e., whether the objects stay at rest relative to each other. In flat, empty space, they do; but in curved spacetime, i.e., where gravitating bodies are present, they don't. For example, if at some instant two rocks are at rest high above the Earth, at slightly different altitudes, they won't stay at rest relative to each other; the one that's lower will fall slightly faster, so the rocks will move apart with time. That is spacetime curvature; and since what I've described is just tidal gravity, we can say that spacetime curvature is tidal gravity.
CKH said:
I'm not sure what has become of concepts like potential energy in GR.
As I said before, potential energy only makes sense in a stationary spacetime. The reason is that potential energy is energy that depends on an object's position; and if spacetime is not stationary, then there is no way to define "position" in a way that's invariant (i.e., that is independent of coordinates). In a stationary spacetime, you can use the worldlines along which the geometry is not changing to mark out "positions"; but in a non-stationary spacetime, there are no such worldlines.
CKH said:
does GR deny that the KE of expansion is converted into gravitational potential energy (whatever that is) over time?
Yes, because the universe is not stationary. There are ways to interpret the dynamics of a closed universe as expansion converting kinetic energy to "potential energy", but that requires defining "potential energy" a different way, and IMO doesn't really add anything to understanding because it doesn't generalize.
CKH said:
I've been told that conservation of energy/matter no longer holds in GR.
That's not quite right. Local conservation of energy holds just fine; the mathematical expression of this is that the covariant divergence of the stress-energy tensor (the mathematical object that describes "matter and energy" in GR) is zero. In ordinary language, this is saying that matter/energy can't be created or destroyed at any location in spacetime.
The problem is trying to come up with a definition of "energy" that is global, not local. Again, this only really works in certain kinds of spacetimes, and the definitions don't generalize well.
CKH said:
Maybe GR implies that perpetual energy generators are possible?
It most certainly does not. That would violate the local conservation of stress-energy that I described above.
