Sinusoidal Wave: What is Time Displacement?
  • Thread starter Thread starter greg997
In the discussion on sinusoidal waves, the phase angle α in the sine wave expression y=Asin(ωt±α) is clarified, with a focus on time displacement. Time displacement is interpreted as the duration it takes for the sine wave to complete a cycle, which is calculated as T=2π/ω. The relationship between time points t1 and t2 in a sine wave cycle is established, showing that t2=t1+2π/w. There is some confusion regarding whether time displacement refers to the phase angle or the time period. The conversation concludes with a suggestion that the term "time displacement" needs a clearer definition to address the original question.
greg997
If the expression forsinewave is y=Asin(ωt±α)
then α is the phase angle.
But what is time displacement looking at that expression?
Thank you
Time displacement? I assume you mean how long it takes for the sine wave to repeat a cycle, or its [STRIKE]frequency[/STRIKE].
All sine waves repeat every 2\pi units. So what we're looking for is
wt_1+\alpha+2\pi
to be equal to
wt_2+\alpha
and we want to find t2 in terms of t1, t2>t1
So equating each expression and simplifying:
wt_1+\alpha+2\pi=wt_2+\alpha
wt_2=wt_1+2\pi
t_2=t_1+\frac{2\pi}{w}
So clearly from this, we can see that the time it takes from the first point in a cycle (t1) to the next (t2) takes 2\pi/w time.
Also to get a more intuitive understanding of this, just think about the length of a complete cycle for sin(x), then sin(2x), sin(x/3) - which is the same as sin(1/3*x) etc.
edit: meant to say period, not frequency.
Thank you for your really good explanation.
But I am not sure this is the answer to the question I was given. I am not sure.
Can frequency and time period T be called time displacement? Is it not about that phase angle?
Thanks any way
Is it ω that is worrying you?
ω is an 'angular velocity' it is the number of cycles (given in radians) completed per second
1 cycle is 2∏ radians and therefore ω = 2∏/T where T is the time for 1 cycle... the time period
So T = 2∏/ω
and frequency f = 1/T = ω/2∏
Hope this helps
Thank you
You haven't given the definition of "time displacement". If you write<br /> sin(\omega t \pm \alpha) = \sin(\omega(t \pm \frac \alpha \omega)) is it the \pm\frac \alpha \omega you want? (Notice that is a question; I'm just guessing here).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
