What Determines the r_0 Constant in Nuclear Radius Calculations?
  • Thread starter Thread starter mateomy
    Atomic Nucleus
mateomy
I've been noticing that for expressions finding the nuclear radius there is a constant term r_0, that I can't seem to find an explanation for. The full term is
R=r_{0}A^{1/3}
That the atomic radius is roughly the 3rd root of the number of nucleons. But where is the r_0 coming from? I'm using Cottingham and Wong as sources but both of them fail to mention it's derivation. Plus, they both give {slightly} different values, without looking I think Wong assigns it a value of 1.7 fm and Cottingham 1.1 fm. Can anyone explain this to me?
Thanks.
Nuclei are sort of fuzzy and don't have definite radii (they're not even necessarily spherical). The formula gives an approximate value of the radius and the value of ro in the formula is determined from various experiments. See http://en.wikipedia.org/wiki/Nuclear_size.
This is I think an expression found by experimental or at least phenomenological means. As there ##A## is the number of nucleons, you would have that ##r_0## is the size of a single nucleon (and has to be determined experimentally of course). It is needed in this expression formally to give the right dimension to ##R##.
Also notice that (something I think is interesting) if you compute the volume of the nucleus (interpreting really ##r_0## as the radius of the single nucleon), you will have that the total volume is ##A## times the volume of a nucleon, which is clearly consistent with what one would imagine.
Looking in the Wikipedia article to the values given for the experimental sizes of neutron and proton, indeed ##r_0## is a constant determined empirically and seems to me a sort of mean value of the two.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
