Sketch & Evaluate Region of Integration
korr2221
http://qaboard.cramster.com/Answer-Board/Image/cramster-equation-20081241616516336400421111250005486.gif
1. Sketch the region of integration
2. Rewrite the integral in the order: dydxdz
3. Evaluate the integral (using either order)The attempt at a solution
Attached.
alternative link:
http://www.yourfilelink.com/get.php?fid=476767
corrections made about my sketch
alternative:
http://www.yourfilelink.com/get.php?fid=476770
You seem to have draw the base as a rectangle when it should be a triangle but since you have not marked which axis is the x-axis, which the y-axis, and which the z-axis, I can't be sure.
If you intended the axis on which "2" is marked to be the x-axis, then you have drawn a "left handed" coordinate system when the standard is "right handed"- curling the fingers of your right hand from the x-axis to the y-axis, your thumb should point in the direction of the positive z-axis.
Since the "outermost" integral is from x= 0 to x= 2, mark vertical lines at x= 0 and x= 2 on the xy-plane.
Since the second integral is from y= 0 to y= x, draw the line y= x on the xy-plane. That gives a triangle with vertices at (0,0), (2,0), and (2,2).
Since "innermost" integral is from z= 0 to z= 2- x, that triangle is the base and the top of the region is the plane z= 2-x. That slopes downward from x=0, z= 2 on the left to x=2, z= 0 on the right.
uh, i believe you aren't looking at the corrections, the first one, in the first page is something else... sorry
9K
