Sketching inequalities involving complex numbers
phosgene
Sketch all complex numbers z which satisfy the given condition:
|z-i|\geq|z-1|
z=a+bi
|z|=\sqrt{a^{2}-b^{2}}
First I find the boundary between the regions where the inequality holds and does not hold by replacing the inequality sign with an equality sign. Then I substitute z=a+bi into the equation and solve for b:
|(a+bi)-i|=|(a+bi)-1|
\sqrt{(a)^{2}+(bi-i)^{2}}=\sqrt{(a-1)^{2}-b^{2}}
a=-b
So the boundary cuts through the origin and has a slope of -1.
To find which side of the boundary the equality holds, I can plug random values from different sides of the boundary, in this case z=-1-i and z=1+i.
Doing this, I get \sqrt{-3}\geq\sqrt{3} and \sqrt{1}\geq\sqrt{-1}
What do I do from here?
This is incorrect. |z| = \sqrt{a^2+b^2}
You can also solve this without using a and b, in a rather simple way. This how I would try, by drawing the graph. |z-i| represents all circles(vectors) with center at (0,1) and |z-1| represents circles with center (1,0). The perpendicular bisector of the line joining these two points gives the condition when |z-i|=|z-1|. So, which side of the curve would you sketch z, such that |z-i|>|z-1|?
Try drawing a graph, and it should become really simple to figure out :smile:
Ah, I thought i was included in the formula. I re-did the entire thing with the correct form, and I got it now. Thanks! :)
Graphically, modulus/absolute value represents the magnitude of distance between the point and origin. Keeping that in mind, its easy to see why it comes out to be \sqrt{a^2+b^2}
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
