Skier going down a hill force and motion question
The discussion focuses on calculating the time taken and distance traveled by a skier on a 5-degree incline, given an initial velocity of 3.5 m/s and a coefficient of kinetic friction of 0.20. The skier's mass is 25 kg. The calculations reveal that the acceleration due to gravity and friction results in a deceleration of approximately -1.78 m/s². Consequently, the time taken for the skier to come to a stop is calculated to be approximately 3.6 seconds, and the distance traveled down the hill is approximately 0.39 meters.
  • Understanding of Newton's second law of motion
  • Basic knowledge of trigonometric functions (sine and cosine)
  • Familiarity with kinematic equations
  • Concept of friction and its coefficients
  • Study the derivation of kinematic equations in physics
  • Learn about the effects of friction on motion in inclined planes
  • Explore the application of Newton's laws in real-world scenarios
  • Investigate the role of mass and incline angle in motion dynamics
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of motion on inclined surfaces.
zeion
A sight seen on many "bunny" hills across Ontario is young skiers pushing on ski poles and gliding down a slope until they come to rest/ Observing from a distance, you note a young person (approximately 25 kg) pushing off with the ski poles to give herself an initial velocity of 3.5m/s^2. If the inclination of the hill is 5.0 degrees and the coefficient of kinetic friction for the skis on dry snow is 0.20, calculate
a) the time taken for the skier to come to a stop
b) the distance traveled down the hill
V final ^2 = V initial ^ 2 + 2 a t
a)
Given:
m = 25kg
V initial = 3.5 m/s^2
Angle of hill = 5 degrees
coefficient kinetic = 0.20
I need to find acceleration to use that formula to find time, acceleration down the hill with no initial velocity and just gravity is Fg parallel to the hill - Fk kinetic friction acting in the opposite direction.
Given:
m = 25kg
Fg parallel to hill = mg sin 5
Fk parallel to hill = mg cos 5 0.20
Fg = (25kg)(9.8m/s^2)(sin5) = 21.35kgm / s^2 < Why are my units weird here?
Fk = (25kg)(9.8m/s^2)(cos5)(0.20) = 48.81kgm / s^2
21.35 - 48.81 = -27.46
The kinetic friction is greater than gravity parallel to hill, does that mean the skier can't move down with just gravity alone?
Or maybe the value I found for "Fk" is not kinetic friction because I think it might just be the Fn acting perpendicular to the hill. So then how do I find Fk?
Fk = Fn 0.20 ?
But I've already applied the friction coefficient to find Fn.
So then what is -27.46? Is it the acceleration parallel to hill due to gravity?
Assuming I have found the correct value for acceleration,
V final ^2 = V initial ^2 + 2at
V final is 0
V initial is 3.5m/s
t = -V initial ^ 2 / 2 a
t = (-3.5m/s)^2 / 2(-27.46m/s^2)
t = 0.22s
b)
Assuming I have found the correct value for t
d = v average t
Do I use this formula to find d?
If V final = 0 is V average = 3.5m/s + 0 / 2 = 1.75m/s?
So,
d = (1.75m/s)(0.22s)
d = 0.39m
makes sense. So
ma = mg sin 5 - mg cos 5 0.20 downhill
a = g(sin5 - cos5)
Negative means it is decelerating.
a = g(sin5 - cos5)
I don't really understand how you arrived at this. You mean that total force going down parallel to hill = Fg - Fk, this is Fa, and Fa = ma, so ma = mg sin 5 - mg cos 5 0.20.
And then you factored out the mg so it becomes mg (sin 5 - cos 5 0.20) = ma, and then you cancel out the m, so should it be a = g(sin 5 - cos 5 0.20) ? How come there is no mu kinetic (0.20) in your equation?
If this is so, then
a = (9.8m/s ^ 2)(-909038955)(0.20) = -1.7m/s ^ 2
Which is not what I get if I don't do the factoring and canceling of m. Does this mean I always have to factor and cancel out terms to get the right answer?
So assuming now I have the correct value for a = -1.7m/s^2, I can find the time with this formula?
t = (-3.5m/s)^2 / 2(-1.7m/s^2)
t = 3.6s
Is this correct?
Quite right - the .2 slipped away on me - good catch!
The idea is to write that the sum of the forces along the ramp equals ma, then find a.
You don't need to cancel the m's, but it saves calculations.
I'm getting a = -1.10. I don't know if you or I have the error.
There is something the matter with this. The basic formula is Vf = Vi + a*t
so t = (Vf - Vi)/a
Ok, so this is what I'm doing
a = g[(sin 5) - (cos 5)](0.20)
a = (9.8m/s^2)[(0.087155742) - (0.996194698)](0.20)
a = (9.8m/s^2)(-0.909038956)(0.20)
a = (9.8m/s^2)(-0.181807791)
a = -1.781716344 m/s^2
And yes I see I have copied the formula for t wrong, thank you.
13K
