Help Solving a Sled Friction Problem
  • Thread starter Thread starter saralsaigh
    Friction
A sled is moving at 4.00 m/s on snow with a kinetic friction coefficient of 0.05. To determine how far it travels before stopping, the sled's acceleration can be calculated using the formula a = Uk * g, where g is the acceleration due to gravity. The mass of the sled is not needed for this calculation since it cancels out in the equations. The final distance the sled travels before stopping is 16.3 meters. Understanding the relationship between friction and acceleration is key to solving this problem.
saralsaigh
Sled question
I have a physics midterm tonite and i was trying some of the practice tests and i got stuck on this question, ur help would be greatly appreciated :)
1. The problem:
A sled is traveling at 4.00m/s along a horizontal stretch of snow. The coefficeint of kinetic friction is Uk=0.05 and the coefficient of static friction Us=0.07. How far does the sled go before stopping?
2.This is my thought process:
Ok I am assuming its moving at constant speed and the acceleration is negative so i drew the FBD with weight down, normal forced up and force of kinetic friction to the left. (Assuming its moving to the right) i thought that Fnet= force of friction (x-direction) = m a , and that by solving for acceleration i can use it to find out the distance however i don't have mass so I didnt know wat to do?! Any suggestions?
3. The answer is actually 16.3m
Why would you need to know the mass?
I think if you just follow thru with what you have done already, you are there:
set ma=frictional force and solve for a.
well if what i said was correct and fnet(x-direction) = ma = Ff, then
ma = Ukmg right? ohhh ic...lol so a=Ukg... my bad this is where i make another stupid mistake...THANKS
