How Does Mass and Inertia Affect Acceleration on an Inclined Plane?
A block with a mass of 5.00 kg slides down a 36.9-degree inclined plane, facing kinetic friction with a coefficient of 0.23. The problem involves a flywheel with a mass of 28.0 kg and a moment of inertia of 0.500 kg*m^2, affecting the tension in the string attached to the block. The equation derived for tension includes gravitational forces and friction, leading to an expression that relates the block's acceleration to the flywheel's moment of inertia. The correct acceleration was found to be approximately 1.165 m/s^2, while a common rounding error led to confusion with the answer of 1.1 m/s^2. The discussion highlights the importance of accurately incorporating the flywheel's mass and moment of inertia in solving the problem.
ASUengineer16
A block with mass m = 5.00 kg slides down a surface inclined 36.9 degrees to the horizontal (the figure View Figure ). The coefficient of kinetic friction is 0.23. A string attached to the block is wrapped around a flywheel on a fixed axis at O. The flywheel has mass 28.0 kg and moment of inertia 0.500 kg*m^2 with respect to the axis of rotation. The string pulls without slipping at a perpendicular distance of 0.200 m from that axis.
I tied solving for the sum of torques, which is T*r=I*(\alpha) where T is the tension and r is the radius of the pulley, .200 m. I think solved for T for the box. Once solving for T I got, T=mg(sin(theta)-cos(theta)*\muk)-m*a. Then using the rule, \alpha=a/r, I then substituted a/r for all the \alpha's and then plugged my T for the torque equation into the T from the force equation.
In the end I came up with the equation:
mg(sin(theta)-cos(theta)*\muk)-m*a = (I*a)/r^2
This yeilded me the wrong answer and I have no idea where I am wrong. I have a feeling it has to do with the mass of the pulley since it was given, but I am not sure how to relate it to the problem since they give you the moment of inertia for the pulley ?
Any help would be great thanks !
Hi ASUengineer16,
What wrong answer did you get?
After solving for a in the final equation I got 1.1 m/s^2
actually seems like I made a rounding error, the correct answer was 1.165 m/s^2 but it wouldn't take 1.1 when I entered it,
and for part b, 14.6 N came out to be correct with 1.2 m/s^2 as the acceleration.
I was about to write back that I kept getting 1.16619 for the acceleration.
Glad it worked out.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
