Troubleshooting C++ Program: Invalid Conversion Error
  • Thread starter Thread starter Zurtex
    C++
The discussion centers on a C++ programming error related to character assignment. The user encounters an "invalid conversion from `const char*` to `char`" when trying to assign a string literal "=" to a character variable. It is clarified that single quotes ('=') should be used for a single character, while double quotes ("=") denote a string. The distinction between character pointers and character types is emphasized, with the correct syntax being crucial for successful compilation. Understanding this difference resolves the user's issue with the program.
Zurtex
Homework Helper
Just been introduced to the world of C++ as I'm taking a course on it in my maths degree. We are asked to write a simple program that takes in 3 numbers, sorts them in terms of order and then outputs them.
Not going to type my full program as that would probably be a waste of your time but here are the two important lines I am stuck on:
char qualifier1;
qualifier1 = "=";
And I'm getting the error when I try to compile this:
invalid conversion from `const char*' to `char'
Can anyone help me please, I'm not sure what this means and I am struggling to fix it.
i believe the correct syntax for a single char is ' ' not " "...if i remember correctly " " denotes strings...and thus your error is saying
cannot convert const char* "=" (string) to a char (single char qualifier)
Using double quotes ("") in C and C++ returns a constant character pointer which points to a null-terminated string in the static section of memory. So if you write char* ptr = "dog"; you get ptr pointing to a character array consisting of 'd', 'o', 'g', and '\0', the null terminator.
What you're looking to do is use single quotes. When you type "=", you get the C-string "=". What you want to do is '=', with single quotes. This returns a plain character.
Edit: whoops too late
Thanks :biggrin:
34K
