Optimizing Solar Water Heater Efficiency for Pool Heating
To optimize solar water heater efficiency for pool heating, the discussion highlights the challenge of calculating the new pool temperature after heating a portion of the water. It confirms that while temperature changes can be considered linear in average energy, heat transfer with the environment is not linear, affecting efficiency. Continuous water circulation through the solar collector is recommended to enhance heating efficiency, rather than heating a smaller volume intermittently. Additionally, as the pool temperature rises, the rate of heat loss will increase. A generalized heat transfer formula for water is suggested as a potential solution for more accurate calculations.
tomot
I thought Wolfram Alpha might be able to help me with this problem, however
so far I have had no luck, with the website nor their community:
I have a 1230 gal pool heated by the sun to 70 degrees F, If I remove 30 gal
and let the 30 gal be heated in my solar collector to 100 degree F, and then add it back to the pool.
What will my new pool temperature be?
Is this raise in temperature linear? meaning if continue to do this once every hour via a timer and a pump can I extrapolate how long it will take to raise the pool temperature to 80 degrees?
TIA!
Science news on Phys.org
Temperature is linear in average energy, so yes.
But, heat transfer [with the outside environment, rather than by direct mixing of enclosed fluids] is not linear. The solar heater will be more efficient if the water constantly pumps through it instead of overheating a smaller volume (and the pumping heats the water too). On the other hand, heat sinking pipes could reverse this. Also, the higher the pool temperature gets, the faster it will be cooling.
thanks for your reply! I presume then that I really need to look for is a generalized heat transfer formula for water, if there is such a thing?
