Calculating Force for Tattoo Machine Solenoids
The discussion focuses on redesigning solenoids for tattoo machines and seeks a formula to calculate the force exerted by the solenoid on the armature. Key variables such as flux density and air gap length are identified as known factors in the calculation. Participants are encouraged to share any relevant formulas or methods to relate these variables to the force produced. The conversation aims to provide practical solutions for optimizing tattoo machine performance. Overall, the thread emphasizes the importance of accurate calculations in solenoid design for tattoo machines.
d1983
I'm currently in the process of redesigning the solenoids for a tattoo machine company. I was wondering if anybody was aware of a formula to find the amount of force that the solenoid would draw the armature. I can figure out just about every variable that I think I'd need: flux density, air gap length etc. I just need some way to relate that to the amount of force it would create.
Thanks everyone.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
