Solenoid produces a magnetic field help
A solenoid measuring 0.20 m in length with 100 turns generates a magnetic field of 1.5 mT. The current in the coil can be calculated using the formula I = BL/μN. Substituting the values, the initial calculation yields approximately 23.87 A, but this assumes an infinite solenoid. A more accurate calculation, considering finite length, gives a current of approximately 0.024 A. The discussion highlights the importance of the solenoid's assumptions in magnetic field calculations.
predentalgirl1
1. A solenoid is 0.20 m long and consists of 100 turns of wire. At its center, the solenoid produces a magnetic field with a strength of 1.5 mT. Find the current in the coil.
2. L be the length of the solenoid = 0.2m
N be the number of turns = 100
B be the magnetic field = 1.5 mT = 1.5 x 10-3 T
I be the current in the coil in ampere
μ be the permeability in air = 4 π x 10-7 H/m
in a close circuit magnetic field
B = μNI / L
3. So, I = BL / μN
= (1.5x10-3 x 0.2) / (4 π x 10-7 x 100)
= 3 x 10-3 / 1256.637061 x 10-7
= (3/1256.637061) x 104
= 23.87324147 A
( Ans)
Were you looking for a correct? It's correct.
Yes, I was. And it really is? Yes!
Well, technically, it isn't because the derivation you used assumes an infinite solenoid. :p
It is what your professor/teacher would be looking for though. :)
Given that,
L = 0.20m, n = 100 turns, B = 1.5 x 10 ^-6 T
have I = B/μo . l
= 1.5 x 10^ -6 x 0.20/4 x 3.14 x 10 ^-7
=0.024 x 10 A
=2.4 10 ^-2 A
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 21 ·
