How Much Epsom Salt for a 15% Magnesium Sulfate Solution?
  • Thread starter Thread starter HarryA
    Magnesium
To create a 15% magnesium sulfate solution using Epsom salts (MgSO4·7H2O), the calculation involves determining the required mass of Epsom salts based on the desired amount of magnesium sulfate. The molecular weights are confirmed: MgSO4 is 120.36 g/mol and MgSO4·7H2O totals 246.36 g/mol. To achieve 1.24 pounds of MgSO4, the calculation suggests needing approximately 2.54 pounds of Epsom salts. Additionally, the water content in Epsom salts, which is about 51.14% by weight, must be factored into the total weight. The discussion emphasizes the importance of accurate proportioning for effective solution preparation.
HarryA
I would like to make a solution of magnesium sulfate (MgSO4) that is 15%
magnesium sulfate by mass in water. As magnesium sulfate is sold as epsom salts which is
MgSO4 7H2O I need a way to calculated the epsom salts required for the required
magnesium sulfate or 1.24 pounds per gallon of water (Water at 8.35 pounds per gallon).I am thinking one goes by atomic weight?
For MgSO4:
Mg= 24.3 S= 32.06 Oxgen4= 4* 16 = 64 MgSO4= 120.36
For 7H2O:
7H2 = 7*1*2 = 14 7Oxgen = 7* 16 = 112 7H2O= 126.0
For MgSO4 7H2O= 120.36 + 126.0 = 246.36
So to get 1.24 pounds of MgSO4: 1.24 * 246.36/120.36 = 2.05 pounds perhaps?
Thanks in advance.
Chemistry news on Phys.org
HarryA said:
MgSO4= 120.36
Check.
HarryA said:
7H2O= 126.0
Check.
Check.
Not check.
Take another swing at the proportion. You'll also want to account for the mass of water you're adding as hydrate.
Thanks.
So the ratio of water in epsom salts is: 126.0/246.36 = 51.14 % by weight and
48.86% MgSO4. So 48.86% of what weight of epsom salts is 1.24 pounds of MgSO4?
Epsom salts = 1.24/0.4886 = 2.54 pounds ?
I need to fill my RC blimp envelope with hydrogen.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
