Solving for k, we get k = 2mgd(sinθ)/x2.
A car with mass m rolls down a frictionless incline and compresses a spring, requiring a specific spring constant to stop within a distance x. The correct relationship derived is k = 2mgd(sinθ)/x², assuming the car starts from rest. Initial potential energy from the height is converted into spring potential energy at maximum compression. The discussion clarifies that objects described as falling or rolling typically start with zero velocity, which is crucial for solving the problem correctly. Understanding these energy transformations is essential for accurately determining the spring constant.
flyingpig
A car with mass m rolls d down a frictionless \theta^0 degree incline. If there is a horizontal spring at the end of the incline, what spring constant is required to stop the car in a distance of x?
[PLAIN]http://img4.imageshack.us/img4/8837/unledxrq.jpg
I am honestly very embarrassed that I can't do these basica problems properly and I am a rising sophomore.
I tried
\sum W = \Delta K
mg(d\sin\theta) - \int_{x = 0}^{x = x} kx dx = -\frac{1}{2}mv_0^2
I thought that at the top before it collides that
-\frac{1}{2}mv_0^2 = -mg(dsin\theta)mg(d\sin\theta) - \int_{x = 0}^{x = x} kx dx = -mg(d\sin\theta)
\int_{x = 0}^{x = x} kx dx = 2mg(d\sin\theta)k = \frac{4mgd\sin\theta}{x^2}
Apparently this is wrong and the answer is just mgh = 0.5kx^2.
I decided to not use LaTeX for the correct answer because I am upset.
If assume initial velocity is 0 I get it right
k = \frac{2mgd\sin\theta}{x^2}
Why? How do I know it started with 0 velocity?
hi flyingpig! :smile:
yes :smile:
(except you really ought to use a different variable inside the ∫, maybe x' or y)
i don't understand where this comes from :confused:
It came from at the top of the ramp.
This is the simple part.
Read the question and look for the following:
An object falls, an object is dropped, a car rolls down a hill, a block slides down a slope, ...
In all these cases the object is starting with zero velocity.
When the question starts
An object is thrown, A projectile is lauched, or similar, it is NOT starting with a velocity of Zero.
Actually "an object is dropped/falls" can be tricky, since it can sometimes be dropped/fall from a moving point - but then you will realize it is moving so it shouldn't be a problem.
Examples could be:
You dropped a book while in a lift traveling up at 2 m/s
A bomb falls from an airplane traveling at ...
A bag of nuts falls out of a roller coaster when it speeds over a crest ...
Good luck
Peter
At the top of the ramp, the car has PE = mgd(sinθ) and KE = 0.
At the point where the spring has stopped the car, the car has PE = (1/2)k(x2) and KE = 0.
Therefore,
mgd(sinθ) = (1/2)k(x2) .​
