Solve for x logarithm question
  • Thread starter Thread starter Ascleipus
    Logarithm
The problem involves solving the equation log(x) = -4x + 5, where the logarithm has base 10. It is noted that there is no straightforward algebraic solution due to the variable x appearing both inside and outside the logarithm. Suggestions include converting to natural logarithms and using the Lambert W function for a more complex solution. Additionally, a numerical approximation method is proposed, where the equation can be iteratively solved by rewriting it as x = (5 - log(x)) / 4. This iterative approach provides successive approximations for the value of x.
Ascleipus
The problem asks to solve for x
log(x)=-4x+5 (the log has base 10 - not natural log)
log(x)=-4x+5
10^-4x+5=x
log(10^-4x+5)=log(x)
-4x+5*log(10)=log(x)
-4x+5=log(x)
seems at first to be a simple enough question to solve, however I only end up with a circular solution bringing me back to the original question when i take the log of this to bring down the exponent (of course)
Any help would be appreciated :)
You could try writing $$log_{10}x=\frac{ln x}{ln10} $$
There isn't going to be any simple "algebraic" way to solve that because you have the unknown, x, both inside and outside the logarithm. The first thing I would do is use CAF123's suggestion to change to natural logarithm: ln(x)/ln(10)= -4x+ 5 so that ln(x)= (-4/ln(10))x+ 5/ln(10). Now take the exponential of both sides:
x= e^{(-4ln(10))x}e^{5/ln(10)}
xe^{(4/ln(10))x}= e^{5/ln(10)}
Now let y= (4/ln(10))x so that x= (ln(10)/4)y and the equation becomes
(ln(10)/4)ye^y= 5^{5/ln(10)}
ye^y= \frac{5^{5/ln(10)}}{ln(10)/4}
and therefore
y= W\left(\frac{5^{5/ln(10)}}{ln(10)/4)}\right)
where "W" is Lambert's W function (http://en.wikipedia.org/wiki/Lambert_W_function) which is defined as the inverse function to f(x)= xe^x
(I told you there was no simple "algebraic" solution!)
Since we defined y= (4/ln(10))x, we have, finally,
x= ln(10)\frac{W\left(\frac{5^{5/ln(10)}}{ln(10)/4)}\right)}{4}
May you have joy of it!
Since this was posted under "Precalculus Mathematics", where in the world did you get this problem?
Should that be ##ln(x) = ln(10)[5 - 4x]?## Instead of taking the exponential of both sides, I then said ##ln(x) = 5ln(10) - 4x ln(10)\,\Rightarrow ln(x) = ln \left(\frac{10^5}{10^{4x}} \right)##. I now take exp to get ##x10^{4x} = 10^5.##
it will be easier to solve this question using Newton-Raphson method. :)
Yes, I messed that up. Thanks for catching it. But that still has no "algebraic" solution. In order to use the W function, you will need to convert to "e". 10^{4x}= e^{ln(10^{4x}}= e^{4xln(10)} so the equation is the same as xe^{4xln(10)}= 10^5.
Let y= 4x ln(10) so that x= y/(4 ln(10)). The equation becomes, in terms of y, \frac{ye^y}{4ln(10}= 10^5. ye^y= 400000 ln(10), y= W\left(40000 ln(10)\right).
Then x= \frac{W\left(40000 ln(10)\right)}{4 ln(10)}
You can solve the equation numerically by iteration.
Rewrite it as
x=(5-log(x))/4,
Get the next approximation from a previous one by xk+1=(5-log(xk))/4.
Using x1=1, substitute and get the next approximation: x2=1.25. Substitute again, now you get x3=1.227 ...
Rewrite it as
x=(5-log(x))/4,
Well, sure, if you want to do it the easy way!
