Solve Limit as x→π/8: (cos(2x)-√(2))/(x-π/8)
  • Thread starter Thread starter batman2002
    Limit Trig
The limit as x approaches π/8 for the expression (cos(2x)-√(2))/(x-π/8) is being analyzed, with the numerator approaching -√(2)/2 and the denominator approaching 0. The discussion highlights confusion over the relevance of the equation cos(2x)+cos(2a), which is deemed not applicable as it is not an identity. Participants note that the limit resembles forms like 1/x and 1/x², which indicate behavior towards infinity. The conversation emphasizes the importance of correctly identifying the limit's characteristics and clarifying misunderstandings about the equations involved. This limit problem requires careful analysis of the numerator and denominator as x approaches the specified value.
batman2002
Find the limit as x approaches ∏/8, (cos(2x)-√(2))/(x-∏/8)
cos(2x)+cos(2a)
I tried to multiply the conjugate of the terms but ended up stuck there, don't know how to go on. Please help.
cos(2x)+cos(2a)
This isn't an equation, and I don't see how it's relevant to anything.
As x approaches \pi/8, what does the numerator approach? What does the denominator approach?
Mark44 said:
This isn't an equation, and I don't see how it's relevant to anything.As x approaches \pi/8, what does the numerator approach? What does the denominator approach?
You end up with -(1/sqrt2)/0 limit. the equation is an identity that is supposed to help when solving the question.
I also tried expanding the relevant equation and ended up with, cos(2x)+cos(2a)=-2sin(x+a)sin(x-a)
cos(2x)+cos(2a) is NOT an equation, so it can't possibly be an identity.
But that's not a number. I agree that the numerator approaches -1/sqrt(2), which is the same as -sqrt(2)/2. And I agree that the denominator approaches 0.
So this problem is similar to these limits:
\lim_{x \to 0}\frac{1}{x}
\lim_{x \to 0}\frac{1}{x^2}
How would you characterize these two? (One of them has a direct bearing on your limit.)
I am not exactly sure about that.
What is it that you're not exactly sure about? If you think that cos(2x)+cos(2a) is an identity, I am absolutely certain that you are wrong.
Are you unsure that your limit is related to one of the ones I gave, you can start by answering my question.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
