Solve this pair of simultaneous equations involving complex numbers
chwala
Solve the simultaneous equation for the complex number ##z## and ##w##,
$$(1+i)z+(2-i)w=3+4i$$
$$iz+(3+i)w=-1+5i$$
Complex numbers
$$iz+(3+i)w=-1+5i$$
ok, multiplying the first equation by##(1-i)## and the second equation by ##i##, we get,
$$2z+(1-3i)w=7+i$$
$$-z+(-1+3i)w=-5-i$$
adding the two equations, we get ##z=2##,
We know that, $$iz+(3+i)w=-1+5i$$
$$⇒2i+(3+i)w=-1+5i$$
$$w=\frac {-1+3i}{3+i}$$
$$w=\frac {(-1+3i)(3-i)}{(3+i)(3-i)}$$
$$w=i$$
There may be a different approach from this...
Likes PeroK
I'm not sure there is anything easier.
Likes chwala
Well, I could debit something that is different/is not different but looks different and is probably not easier :smile::
Consider this a matrix equation ## Ax = y## with solution ##x = A^{-1}y##:$$
\begin{pmatrix} 1+i&2-i\\\phantom{1+}i&3+i\end {pmatrix}
\begin{pmatrix} z\\w\end {pmatrix}=\begin{pmatrix} \phantom{-}3+4i\\-1+5i\end {pmatrix}
\quad \Rightarrow \quad
\begin{pmatrix} z\\w\end {pmatrix} =
{1\over |A| }\begin{pmatrix} 3+i&-2+i\\\phantom{1}-i&\phantom{-}1+i\end {pmatrix}
$$With ## |A| =\det A = (1+i)(3+i)-i(2-i) = 1 + 2i\ ##we get $$
\begin{pmatrix} z\\w\end {pmatrix} = {1\over 1 + 2i }
\begin{pmatrix} (3+i)(3+4i)+(-2+i)(-1+5i) \\ \phantom 3\ - i\phantom )(3+4i)+( \phantom{-}1+i)(-1+5i) \end {pmatrix} = {1\over 1 + 2i }
\begin{pmatrix}\phantom{-} 2+4i\\-2+{\phantom 4}i \end {pmatrix} =
\begin{pmatrix}2\\i\end {pmatrix}$$
##\LaTeX## wise this is quite a compact solution :wink: .
Yours could also be slightly more compact if you realize that $$ followed by a carriage return and then $$ for a new displayed equation creates a lot of vertical white spacing. And the more so with two carriage returns (another empty line !).
But that's all beside the mathematical point, where you did just fine!
Likes DaveE, Ibix and chwala
It still takes a while to typeset. *grumble*grumble*deletes*half*complete*post*grumble* :wink:
  • Haha
Likes fresh_42 and BvU
Which is the carriage return syntax? ...you could share a simple math example "with" and "without" carriage return then i can adopt that immediately...
I think the point is that if you write Newton's second law says $$F=ma$$ and is the definition of "force". you get:
Newton's second law says $$F=ma$$and is the definition of "force".​
But I think you're inserting a blank line (or at least a new line) before and after the LaTeX delimiters, so you get
Newton's second law says​
$$F=ma$$​
...which takes up a lot more room vertically.
Thanks, i will check on that Ibix...
This time I had to grmbl grmbl :biggrin:
And I also lost the part I did want to keep :mad:, namely:
I had fun discovering that googling (3+i)(3+4i)+(-2+i)(-1+5i)
(copied straight from the ##\TeX## source!) gives ##2+4i##
But horizontally aligning (-i)(3+4i)+(1+i)(-1+5i) was nightmarish indeed :wink:
@chwala: experiment !
  • Haha
Likes chwala and Ibix
I rarely use $$ for this exact reason. I mostly use ##.
Carriage return -- enter key
Likes chwala
I prefer $$ ...the equations look like a piece of art...I will just need to work on the spacing.
## doesn't bring out the art and desired neatness...particularly on fraction type of equations...
Likes BvU
Also Cramer's Rule, which I probably would have used. A slightly different take on the linear algebra of @BvU's post.
Likes BvU and chwala
Yap...Matrices in the making...
For fractions with ## , use \dfrac for a fraction rather than \frac .
