Solving 2 equations and 2 unknowns with vectors
  • Context: Undergrad
  • Thread starter Thread starter matt382
    Unknowns Vectors
The discussion revolves around solving a system of two equations involving two unknown vector quantities, V1 and V2, represented in polar form. Participants explore the feasibility of finding unique solutions given certain constraints and measurements of related vector quantities Vx, V3, and Vy.
  • One participant suggests that the equations V1 + V2 = Vx and V1 + V2 + V3 = Vy may not provide enough information to separate V1 from V2.
  • Another participant proposes that the equations can be rephrased as U = V1 + V2, indicating that there is insufficient information to determine individual values of V1 and V2.
  • A different viewpoint is presented, arguing that the vector nature of the quantities introduces additional constraints due to angles, suggesting that the system may be more constrained than it appears.
  • One participant emphasizes that if VX equals VY - V3, there would be infinitely many solutions, while if they are not equal, there would be no solution.
  • Another participant attempts to clarify the equations, suggesting a potential unique solution if the equations are structured correctly, although this is met with a correction regarding a typographical error.
Participants express differing views on whether the given equations provide sufficient constraints to solve for V1 and V2 uniquely. Some argue that the vector nature introduces additional constraints, while others maintain that the equations do not allow for separation of the variables.
The discussion highlights limitations in the provided equations, including the potential for multiple solutions or no solutions depending on the relationships between the known quantities.
matt382
Hi, I have a work-related problem to solve and I'm not sure where to start and a pointer would be appreciated. I have the following two sets of polar equations
V1 + V2 = Vx
V1 + V2 + V3 = Vy,
where Vx, V3, and Vy have been measured with reasonable accuracy, maybe +/-2%
Any thoughts on how to approach? If, for example, if I convert to rectangular form and try substitution the entire thing is quickly swimming in a sea of sines and cosines that cannot possibly be solvable
My question is this: There should be enough known to solve, is that right? Can this just go into a matrix and get solved that way?
thanks for any help
hello matt, :welcome:
looks like you do not have enough to solve: all you have is 2 measurements of v1+v2
The equations don't allow you to separate ##V1## from ##V2##. You could set ##V1+V2=:U## and have the same amount of information coded. There is no way to achieve the values of ##V1## or ##V2##.
Hi BvU and fresh_42, I understand your point if they were scalar numbers. But it intuitively feels to me that because these are vectors that there's an additional constraint present in the form of angles that must be achieved.
In the attached, with System 1 of course V1 and V2 have an infinite solution space. But look at System 2: Visually it appears to be completely constrained. If you change the position of V3, then you will break the system 1 constraint that V1 and V2 have a fixed angle between them, for example. And we know both VX and VY. In other words, this looks completely constrained to me--there's no other way to draw the vectors when both systems are considered.
Am I just not seeing this correctly?
No. You need an equation which makes two variables. You have only one variable: ##U=V1+V2##. Often ##V1-V2## does the job, but I don't know your system and whether you can measure the difference.
You have one equation that says V1+ V2= VX and another that says V1+ V2= VY- V3, with VX, VY, and V3 known. If VX= VY- V3 then there are infinitely many solutions. If they are not equal, there is no solution.
HallsofIvy said:
You have one equation that says V1+ V2= VX and another that says V1+ V1= VY- V3, with VX, VY, and V3 known. If VX= VY- V3 then there are infinitely many solutions. If they are not equal, there is no solution.
The situation has two unknowns ##x=V1## and ##y=V2##, and two known variables ##a=VX## and ##b=VY-V3\,.## The equations now read ##x+y=a## and ##2x=b##. This can always uniquely be solved.
That's just a typo !
  • · Replies 24 ·
