Solving a Recurrence Relation Using Induction: Step-by-Step Guide
The discussion revolves around understanding the application of mathematical induction to solve a recurrence relation, specifically in the context of Picard iterates and their properties. Participants explore the definitions and implications of certain equations, particularly focusing on the conditions under which the induction hypothesis holds true.
  • Some participants express confusion about how induction is applied, particularly in deriving the formula for when n=j+1 from n=j.
  • There is a discussion about the definition of ##y_n(t)## and its relation to Picard iterates, with some participants confirming their understanding of equation (5) as ##|y_n(t)-y_0| \leq M(t-t_0)##.
  • One participant notes that the use of the induction hypothesis is crucial for establishing that ##|f(s,y_j(s))| \leq M##, but questions whether this follows directly from the induction step.
  • Another participant emphasizes that the rectangle R, defined by constants a and b, is essential for ensuring that the function f remains bounded by M.
  • There is a concern about the clarity of the book's explanation, with some participants feeling that additional context would have been helpful.
Participants generally agree on the definitions and the role of the induction hypothesis but express differing views on the clarity of the explanation provided in the book. Some participants feel confident in their understanding, while others continue to seek clarification.
Participants highlight that the conditions under which the induction hypothesis holds depend on the definitions of the constants a and b, which are not fixed and may vary. This introduces uncertainty regarding the applicability of the results derived from the induction process.
bubblewrap
Below I have uploaded the page I am having trouble with.
Here it says that it is using induction on n but I don't understand how it uses the formula for when n=j to derive the formula for when n=j+1
Here it says that it is using induction on n but I don't understand how it uses the formula for when n=j to derive the formula for when n=j+1View attachment 94504
What is the definition of ##y_n(t)##?
I can guess that equation (5) is ##|y_n(t)-y_0| \leq M(t-t_0)##. Is this guess correct?
EDIT: ok, I found it, ##y_n## are Picard iterates.
Equation (5) is ##|y_n(t)-y_0| \leq M(t-t_0)## for ##t_0 \leq t \leq t_0+\alpha##.
So by definition ##y_{j+1}(t)=y_0 + \int_{t_0}^t f(s,y_j(s)) \, ds##
He uses the definition of ##y_{j+1}## and that ##M## is defined as the maximum on the rectangle defined by ##t_0 \leq t \leq t_0+a,\ |y-y_0| \leq b##.
Thanks to the induction hypothesis that he knows that ##|f(s,y_j(s))|\leq M##.
Thanks to the induction hypothesis that he knows that ##f(s,y_j(s))\leq M##.
But he didn't use n=j to show anything since ##f(s,y_j(s))\leq M## is a definition and not something deduced from n=j
Let's rewrite it in the correct order.
By definition, ##y_{j+1}(t)=y_0 + \int_{t_0}^t f(s,y_j(s)) \, ds##.
Let R be the rectangle defined by ##t_0 \leq t \leq t_0+a,\ |y-y_0| \leq b## where ##a, b## are positive numbers.
Let ##M## be the maximum of ##f## on that rectangle.
Set ##\alpha=min(a,\frac{b}{M})##.
Then ##|y_n(t)-y_0| \leq M(t-t_0)## for ##t_0 \leq t \leq t_0+\alpha##. (Equation (5) in your text.)
Assume that it has been proven for ##j##.
So ##|y_j(t)-y_0|\leq M(t-t_0)## for ##t_0 \leq t \leq t_0+\alpha##.
But then ##|y_j(t)-y_0|\leq M(t-t_0) \leq M\alpha \leq b##, meaning that ##(t,y_j(t))## lies in the rectangle R, so that ##|f(t,y_j(t)| \leq M##. This is where the induction hypothesis is crucial.
That's what he uses in the last step: in the integral he just uses ##|f(s,y_j(s)|\leq M##.
This only holds if ##(s,y_j(s))## lies in the rectangle R. He knows it does thanks to the induction hypothesis.
So ##|y_j(t)-y_0|\leq M(t-t_0)## for ##t_0 \leq t \leq t_0+\alpha##. .
Thank you for your help, one last thing, am I slow if I am not getting this?
Do you agree that we are only certain that ##|f(s,y_j(s)| \leq M## if ##(s,y_j(s))## lies in the rectangle R?
Rectangle R depends on the two constants a and b, and these are random numbers right? So although we are not certain about what you said it could be in that condition.
Yes, a and b are two positive constants. They define the rectangle R. M is by definition the maximum of f on that rectangle.
To use that ##|f(s,y_j(s))| \leq M##, you must know that ##(s,y_j(s))## lies in the rectangle R. Do you agree so far?
Yes, sorry I just had dinner. I agree so far.
No reason to be sorry for having dinner. :oldsmile:
Assume that equation (5) has been proved for j.
Now he needs to show that ##(s,y_j(s))## lies in the rectangle R if ##t_0 \leq s \leq t_0+\alpha##.
Equation (5) means: ##|y_j(s)-y_0| \leq M(s-t_0)## for ##t_0 \leq s \leq t_0+\alpha##.
But then ##|y_j(s)-y_0| \leq M(s-t_0) \leq M\alpha \leq b##, by the definition of ##\alpha##. (*)
Remember how the rectangle R was defined?
##(s,y) \in R## if ##t_0 \leq s \leq t_0+a,\ |y-y_0| \leq b##.
Now look at ##(s,y_j(s))## for ##t_0 \leq s \leq t_0+\alpha##.
Obviously ##t_0 \leq s \leq t_0+a##.
But, more interesting, by (*), ##|y_j(s)-y_0| \leq b##.
We conclude that ##(s,y_j(s)) \in R##, and then by definition of M, ##|f((s,y_j(s))| \leq M##. This is what he uses in the last step of his proof. He needed the induction hypothesis to prove that ##(s,y_j(s)) \in R##.
Thank you it's all clear now :) Is the book not self explanatory or am I slow for not getting it in the first place? (I got it now)
It's the book. This point is not very difficult, but one line explaining this would have been welcome.
Now he does explain just before the proof that the lemma means that the graph of ##y_n## stays within the rectangle:
  • · Replies 19 ·
