Solving a Two-Box Frictionless Physics Problem
To solve the two-box frictionless physics problem, it's essential to draw free body diagrams for each box without including the pulley. The tension in the string equals the force acting on mass M, while the weight of mass m is balanced by the normal force from the table. Since the system is frictionless, the forces on both masses are equal, leading to a direct relationship between tension and gravitational forces. Understanding that the pulley only changes the direction of force is crucial. This approach will help in expressing the solution in terms of M, m, and g.
Alw
I have a big physics test tomorrow:cry: , and I can't figure out how to solve this type of problem:
2 boxes, one on a table attached to a string attached to another box hanging off the table. (the table is a frictionless plane)--It wants me to find the force of tension on the string. the diagram is as follows: (rough i know) -- the "/"and "0" represent a rod and a wheel on the end allowign the string to roll freely (again no friction)
[m]-------------0
_____________/ |
......| [M]
I have figured out you need to draw a free body diagram for the boxes, and figured out that Fg = Mg, but that's about as far as i got.
Thanks in advance for the help!:smile:
(There are no values, the answer is supposed to be in terms of M, m, and g)
what you really need to remember is since you considering a massless pully, all it does is change the direction.
Draw your free body diagrams for each box, nowhere should you have a FBD with a pully involved (that was what always got me). Look at the force(s) acting on your system. Try to get the big idea of what is really happening here. What is pulling on what? Try to remember that a pully just changes direction in this system.
Force on M= Tension in string=Force on m.
The only forces in the system are gravity on mass M and the tension of the string.. the weight of m is balanced by the normal force exerted back by the table.. Thus, since there is also no friction both on the table surface and the pully, the force on M & m shld be the same..
tats wat i tink, correct me if I'm wrong.
