Solving Circuit with Three Pathways
  • Thread starter Thread starter pdeco1
    Circuit
The circuit consists of three pathways with resistors and batteries arranged in parallel, including a capacitor between the top and middle rows. The objective is to determine the currents and charge on the capacitor using relevant equations. The user derived equations for current but expressed uncertainty about the correctness of their calculations, particularly regarding the capacitor's role in steady state. A response suggests simplifying the analysis by focusing on steady state conditions, where the capacitor's current is zero, allowing for a straightforward voltage divider approach to find the current and voltage across the capacitor. The discussion emphasizes the importance of understanding the steady state behavior of capacitors in circuit analysis.
pdeco1
This circuit has three pathways, consisting of three parallel horizontal wires, connected by two vertical wires on each end.
Moving from left to right:
The top row has a 3 ohm resistor.
The middle row has a 12V battery with the + end on the left side, followed by a 2 ohm resistor.
The bottom row has a 4 ohm resistor followed by a 12V battery with the - end on the left side.
The left vertical wire has a 2uF capacitor between the middle and top row with the + on the north end.
The question asks to determine the currents and charge on the capacitor.
V = Q/C
V = IR
IF the rows are labeled I(top), I(middle) and I(bottom) then Equation 1: I am = It + Ib
Starting the loop from the left middle intersection and looping through the bottom loop.
-12V - Im2 -12V - Ib4 then reduced
Equation 2: -12V -Im - Ib2
Starting from the same left middle intersection and looping up to the top loop.
-12V - 2Im -3It -Q/2uF
If max Q = CV, then Q = (2uF)(12V) = 24uC
Equation 3 = -24V -2Im - 3It
I am not sure if Equation 3 is correct. As I understand the book, the current through a capacitor is zero due to the capacitor absorbing all of the current, but the voltage is conserved throughout?
If the equations I derived are correct, I am = 84/13, It = 120/13, and Ib = -36/13
Thanks
Unless you're trying to evaluate the transient response rather than the steady state, I might suggest a simplification...
At steady state the current in the capacitor will be zero. That leaves you with a single loop (the bottom loop) with current flowing. You've got a pretty simple voltage divider situation that will then tell you both the current and the voltage across the capacitor...
