Solving Combination Circuits for i, i1 & v
The problem involves analyzing a combination circuit to determine the equivalent resistance, total current, and voltages across specific components. The subject area is electrical circuits, focusing on series and parallel resistor configurations and applying Kirchhoff's laws.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to calculate the equivalent resistance and total current using both series and parallel formulas. Questions arise regarding the correctness of the current calculations and the voltage across components. Some participants suggest using Kirchhoff's laws to set up equations for the circuit.
Participants are actively discussing the validity of the original poster's calculations and exploring different methods to find the unknowns. There is a recognition of the need to clarify the signs of voltages and currents based on the circuit's polarity. Guidance has been offered regarding the application of Kirchhoff's laws.
Participants note potential confusion regarding the direction of current flow and the implications of the circuit's polarity on the calculations. The original poster expresses uncertainty about how to proceed with finding voltage and currents.
timeforplanb
Find the equivalent resistance seen by the source and use the result to find i, i1, and v.
V=IR
for series circuits:
RT=R1+R2+...+Rn
VT=V1+V2+...+Vn
for parallel circuits:
IT=I1+I2+...+In
1/RT=(1/R1+1/R2+...+1/Rn)
since 30Ω and 6Ω are parallel,
1/R=(1/6+1/30)=1/5
R=5
R=5Ω and 3Ω are series, so:
RT=5+3
RT=8Ω
i solved for the i using this:
i=V/R1=48/3
i=16 A
in getting the total current, i did two things. is this the right thing to do?
IT=V/RT=48/8
IT=9.6 A
or this?
IT=VT/RT=(48+v)/8
however, i don't know how to get v there.
or are both of them wrong? help! I'm new to this that's why I'm still a little confused. thank you very much.
Yeah, i is definitely wrong. Why would the full 48 volts of the source drop across the 3 ohm resistor? It wouldn't. I_T, however, should be right, what makes you say that it isn't? 48V/Rt
i wasn't sure, that was all. anyways, how would i compute for the v then? and for i and i1? can you please give me the equations? thank you.
You should use Kirchoff law.
48V=3I_t + 6I_1
and I_t=I_1+I_2, where I_2 is the current through the 30 ohms resistor.
You find I_2 from these equations and then use V=30(ohms)*I_2, but i don't understand what + V - means.. anyway the absolute value should be right, I'm not sure if it's negative or positive, it depends on what that sign means (+ V -)
Note the polarity of the battery in the circuit. The + terminal is on the bottom. Since it's the only source in the circuit you can be sure that it will drive current out of its + terminal and into the circuit. That means that the actual current flows should looks as in the attached figure where they're indicated in red.
Note that these "actual" currents run counter to the currents originally labelled on the circuit diagram. You should assume that those labelled directions (as well as the indicated polarity for v across the 50 Ohm resistor) are the ones that are to be used for purposes of reporting your answers. That is, in this case the values that you will assign to i, i1, and v will be negative.
thank you flyerpower!
gneill - i'll keep that in mind. thanks, too :D
  • · Replies 60 ·
11K
