Solving Distance Traveled Using Coefficient of Friction
To solve for distance traveled using the coefficient of friction and initial velocity, one must consider the relationship between frictional force and acceleration. The equation vf^2 = vi^2 + 2a(xf - xi) can be applied, but the acceleration (a) must be derived from the frictional force, which is calculated using F_f = μF_n. The coefficient of friction (μ) is crucial as it determines the deceleration due to friction. It's important to recognize that mass is not needed directly in this context, as the frictional force provides the necessary acceleration. Understanding these relationships is key to solving the problem effectively.
idontspeakmath
if you are given the coefficient of friction, initial velocity, and asked for the distance traveled, how would you do it? my first instinct is to use the vf^2=vi^2+2a(xf-xi), but i don't think that coefficient of friction is hanging out there for no reason?
You're right - it's not hanging out there for no reason!
What, exactly, is the quantity a you wrote in your equation?
i was assuming a=9.8, but i guess that was bad physics.
i'm tempted to relate this to f=ma, but there's no mass!
man, the last chapter has twice as many equations as the previous chapters combined. :(
Presumably, somewhere in that chapter, there was discussion of the force of friction. Does this ring a bell? F_f = \mu F_n, i.e. the frictional force is proportional to the normal force. Can you guess what the proportionality constant is? :)
