Solving equation with cube roots.
  • Thread starter Thread starter chingel
    Cube Roots
The discussion focuses on solving the equation involving cube roots: \(\sqrt[3]{x+1}+\sqrt[3]{x+2}+\sqrt[3]{x+3}=0\). One participant successfully found a solution, \(x=-2\), by manipulating the equation and factoring. However, confusion arose regarding the transition from \(3x+6=-3\sqrt[3]{x+1}*\sqrt[3]{x+2}*(\sqrt[3]{x+1}+\sqrt[3]{x+2})\) to \(x+2=\sqrt[3]{(x+1)(x+2)(x+3)}\). Clarification revealed that substituting \(-\sqrt[3]{x+3}\) into the equation allowed for the simplification. The resolution confirmed the validity of the steps taken in solving the equation.
chingel
Solve the equation:
What I did was move (x+3)^(1/3) to the other side, cube both sides and when I put them equal to 0 again, I managed to factor (x+2)^(1/3) out of it giving one solution x=-2.
However if I looked up the proposed solution after cubing and a little gathering and grouping it arrived at this:
Which is clear, but then in the next step it is converted to this without explanation:
From there on the solution is just putting it equal to 0 and factorizing, but how did it get to this from the previous? It would imply -(\sqrt[3]{x+1}+\sqrt[3]{x+2}) is equal to \sqrt[3]{(x+3)}, which I don't think it is. Is it wrong or what is up with that?
Look at your original equation:
This means:
\sqrt[3]{x+1}+\sqrt[3]{x+2}=-\sqrt[3]{x+3}
Plug this into:
and cancel out a factor of 3 to give:
Oh, didn't see that, thank you.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
