Solving for a unit speed curve given curvature and torsion (diff. geo)
The discussion revolves around finding a unit speed curve given a specific curvature function k(s) = 1/(1+s^2) and zero torsion. The problem is situated within the context of differential geometry, particularly focusing on the application of the Frenet-Serret equations.
  • Participants discuss the formulation of differential equations derived from the Frenet-Serret framework and the implications of zero torsion on the curve's planar nature. There are attempts to express the curve in terms of its components in the xy-plane and to relate the curvature to the derivatives of these components.
Some participants have offered insights into the nature of the curve and the implications of the torsion condition, suggesting a planar representation. Others have raised questions about the methods for solving the differential equations and have requested further clarification on specific steps in the reasoning process.
There is an acknowledgment of the complexity involved in solving the system of differential equations, with some participants expressing uncertainty about their understanding of the necessary techniques. The discussion reflects a mix of interpretations regarding the approach to the problem.
^_^physicist
Find the unit speed curve alpha(s) with k(s)=1/(1+s^2) and tau defined as 0.
Use the Frenet-Serret equations
K(s) is the curvature and tau is the torsion
T= tangent vector field (1st derivative of alpha vector)
N= Normal vector field (T'/k(s))
B= Binormal vector field (T x N)
K(s) is defined as the norm of T'
Ok I wrote out the matrix for the Frenet-Serret and found the differential equations to solve:
T' = T/(1+s^2) *which implies => (alpha(s))'' = (alpha(s))'/(1+s^2)
N'= -N/(1+s^2) *which implies =>N' = -(alpha(s)''/(1+s^2)
B'=0
Which so far is really quite easy. But here is the kicker, when I try to solve the diff. eq's and go back and check my solutions, my k(s) value is not correct. I feel rather stupid for asking this, but I seem to have forgotten how to treat a systems of diff. eqs. Any thing to kick start my memory for solving this system would be great.
Thanks for any help in advanced.
The answer is a little tricky:
Since the curve is torsionless, then the curve is planar, so that one can think that it lies completely on the xy-plane.
So, you have to find a curve a(s)=(x(s),y(s)). The tangent vector then is a'(s)=(x'(s),y'(s)), and we have the condition that x'^2(s)+y'^2(s)=1, since it is unitary. Here we do the trick: Since the ways to chose x and y are infinite, we assume that they are the antiderivative of a cosine and a sine, with the same angle:
x(s)=int(cos(f(s)))+a
y(s)=int(sin(f(s)))+b
So, the unitary condition on the tangent vector is fulfilled. We need now to find our function f.
To do this, we differentiate the tangent vector and then we calculate the norm of the new vector. Using the chain rule, we obtain that f'(s)=k(s). So, f(s)=int(k(s))+c, and you can then go back to find the curve you're looking for.
sorry for opening this old thread but i have to find a curve with given curvature and zero torsion. I read the answer but i couldn't understand the trick to solve the differential system. Is there anybody who could be more precise? Thanks
Hi
You don't need to solve a differential sistem.
The fact that your curve has zero torsion means that it is planar, so that you can study it as a curve on the xy-plane. This means that you can denote it as a(s)=(x(s),y(s)). But your curve has unit speed, which means that ||a'(s)||^2=x'(s)^2+y'(s)^2=1. A natural assumption then is to set x'(s)=cos(f(s)) and y'(s)=sin(f(s)). Integrating these expressions we obtain
x(s)=int(cos(f(s)))+a,
y(s)=int(sin(f(s)))+b. (1)
Now, if we differentiate the tangent vector a'(s), we obtain a''(s)=f'(s)(-sin(f(s)),cos(f(s))) using the chain rule. We know that the curvature k(s) is defined as
k(s)n(s)=a''(s),
where n(s) is the normal vector. This yields f'(s)=k(s). Integrating again, we find that f(s)=int(k(s)). Once we obtain f(s), we substitute in (1) and hence obtain a(s).
