Solving For Efficiency & Wasted Thermal Energy in Coal-Fired Plant
The discussion centers on calculating the efficiency and wasted thermal energy of a coal-fired power plant generating 600MW using 4.8 million kg of coal daily. The initial approach incorrectly applies Carnot efficiency, while the correct method involves using the Rankine cycle to determine efficiency based on the heat extracted from the fuel. The thermal power extracted is calculated using the heat of combustion and mass flow of fuel, leading to the formulation of electric power generated and wasted thermal energy. Participants emphasize the importance of understanding the specific cycle used in the plant rather than defaulting to Carnot efficiency. The conversation concludes with advice to clarify misconceptions about efficiency calculations in thermodynamic systems.
roland8727
Seriously Stuck..
A coal fired plant generates 600MW of electric power. The plant uses 4.8 x 10^6 kg of coal a day. The heat of combustion of coal is 3.3 x 10^7 J/kg. The steam that drives the turbines is at a temperature of 573K, and the exhaust water is 310K.
1.) What is the overall efficiency of the plant for generating electric power?
2.) How much thermal energy was wasted?
Ok..this is what I THINK I know...Qh= 3.3 x 10^7 J/kg
Th= 573K Tc= 310K
mass= 4.8 x 10^6 kg
Therefore Carnot effeciency is e=Th-Tc/Th
so Carnot eff. worked out is about 46%
AND I know that P=W/t = Fd/T = FV
Now...I get lost...I know I need to find the Work, to find my Qc...but they only gave me power in MW, and I need to find wasted thermal energy?? Any thoughts??
Th= 573K Tc= 310K
mass= 4.8 x 10^6 kg
Wrong. Why are you using the Carnot efficiency? Is there Carnot anywhere here?. Which cycle is using the plant? Sure it is not the Carnot cycle. It's the Rankine cycle.
-Thermal power extracted from the hot focus:
\dot Q_h=\dot m_{fuel} h_{fuel} where h is the heat of combustion and m is the mass flow of fuel.
- Electric Power generated=Mechanical Power extracted from the turbine rotor (assuming electric efficiency near 1). So that, the efficiency is given by:
\eta=\frac{\dot W_{electric}}{ \dot Q_h}
Due to the first principle:
\dot W= \dot Q_h-\dot Q_c being the last term the heat power wasted to the cold focus. The question of your problem about wasting thermal energy is bad formulated. It means the heat power wasted. You know, due to the second principle some amount of heat extracted from the fuel has to be wasted to the cold environment.
What do you think?
Thanks!...I found the Qh by using the Qh=mh equation...
I found the Work by saying that there is 600MW of Power a day...so, 6 x 10^8 Watts of Power a day, 3600 times 24 will equal 8.64 x10^4 seconds in a day...
P=W/T 6 x 10^8W (8.64 x 10^4s) = Work
And then I have to solve for Qc for thermal energy waste.
Using the first law Qh= W + Qc
And after much thought I think I got the right answer...lol.
Of course, I'm not going to check the numerics, but if you want an advice, think of why did you used the Carnot efficiency. It is a misconception you have to be sure you have understood why it is wrong. All of student begineers here seem to run automatically towards Carnot efficiency when you hear the word efficiency. It is not the first time.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
