Solving IVP using Laplace Transforms
The problem involves solving an initial value problem (IVP) using Laplace transforms, specifically the equation x'' + x = cos(3t) with initial conditions x(0) = 1 and x'(0) = 0. The context is within the subject area of differential equations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of Laplace transforms to the given differential equation, with one participant attempting to set up the equation in the Laplace domain. Questions arise regarding the use of partial fractions and the handling of terms in the equation.
Some participants provide guidance on the approach to take with partial fractions, while others express uncertainty about how to proceed with specific terms in the equation. There is an ongoing exploration of the setup and manipulation of the Laplace transformed equation.
Participants are navigating the complexities of Laplace transforms and the specific algebraic manipulations required, indicating a focus on understanding the process rather than reaching a final solution.
daemon_dkm
"Use Laplace transforms to solve the initial value problem" from section 4.2 in Elementary Differential Equations (6th ed.) Edwards & Penny
x'' + x = cos3t; x(0) = 1 & x'(0) = 0
L{coskt} = s/(s²+k²)
Apparently the answer is 1/8[9cos(t)-cos(3t)].
x'' + x = cos3t
L{x''} = s²*X(s) - s*1 - 0
s²X(s) - s + X(s) = s/(s²+3²)
X(s)(s²+1) = s/(s²+3²) + s
X(s) = s/[(s²+3²)(s²+1)] + s/(s²+1)
This is where I get stuck. Do I get a common denominator then do partial fractions?
There's no need to get a common denominator. Just use partial fractions to break up the first term.
What do I do with the right most part then?
Would I set it up like
= (As+B)/(s²+3²) + (Cs+D)/(s²+1) + s/(s²+1)
s = (As+B)(s²+1) +(Cs+D)(s²+3) + s(s²+3²)
You can ignore the last part for now, so you want to start with
[tex]\frac{s}{(s^3+3^2)(s^2+1)} = \frac{As+B}{s^2+3^2}+\frac{Cs+D}{s^2+1}[/tex]
Then
[tex]X(s) = \frac{As+B}{s^2+3^2}+\frac{Cs+D}{s^2+1} + \frac{s}{s^2+1}[/tex]
Thank you! That's just what I needed to know!
Because then
0s3 = A3 + C3 => A = -C
0 = B2+D2
0 = B + 3D
s = As + 9Cs
1 = -C + 9C
1 = 8C => C = 1/8 so A = -1/8
[tex] X(s) = -\frac{1}{8}\frac{s}{s^2+3^2}+\frac{1}{8}\frac{s}{s^2+1} + \frac{8}{8}\frac{s}{s^2+1}[/tex]
[tex] x(t) = L{X(s)} = -\frac{1}{8}\cos(3t)+\frac{9}{8}\cos(t)[/tex]
  • · Replies 26 ·
