Solving Log Equations (Different Bases)
  • Thread starter Thread starter MPQC
    Bases Log
The equation 2(3^x) = 7(5^x) presents a challenge due to differing bases. The initial approach using logarithms was flawed because it incorrectly applied log laws. The correct method involves dividing both sides by 7 and 3^x to isolate x, leading to the equation 2/7 = (5/3)^x. By taking the logarithm of both sides, the solution can be expressed as x = log(2/7) / log(5/3). This method effectively resolves the equation without needing to convert to a common base.
MPQC
Only the equation: 2(3^x) = 7(5^x)
N/A
Okay. I've been fine learning the loglaws, until I hit this question. If they were the same base (or at least near the same, ex: 2 & 8) then I could simply change them into the same base, and proceed. But I can't do that for this question - neither can I just throw "log" it all. (Though that's my solution for now - I'm really not sure how I should proceed.)
So here's what I've tried:
2(3^x) = 7(5^x)
log (2(3^x)) = log (7(5^x))
x log (2(3)) = x log (7(5))
x log (6) = x log (35)
x = x ( log (35) / log (6) )
x = 1.98x
Well that doesn't work out too well.. I've tried googling the answer - but all I get is examples with the same base, or a base that I can change to make them the same. So how could I solve this?
from here
the next line should be
lg2+lg3x=lg7+lg5x
Thanks so much. I had learned to put them together, but the thought of splitting them back up never occurred.
The crucial point is that 2(3^x) is NOT (2(3))^x so that ln(2(3^x) is NOT x ln(2(3)).
Here's an alternate solution:
2(3^x)=7(5^x)
2/7=(5^x)/(3^x) Divide both sides by 7 and by 3^x
2/7=(5/3)^x
log(2/7)=log((5/3)^x)
log(2/7)=x log(5/3)
log(2/7)/log(5/3)=x
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
