Solving Massless Pulley: Finding Accelerations, Tension & Pulley Motion
The discussion revolves around solving a physics problem involving a massless pulley system with two unequal masses, m1 and m2, connected by a string. An external force is applied to the pulley, and participants explore how to find the accelerations of the masses, the tension in the string, and the acceleration of the pulley. The approach involves considering two reference frames and using the relationship that the total length of the string remains constant. Participants suggest writing position equations for each mass and applying Newton's second law to derive the necessary equations, while some express concerns about having too many unknowns relative to the equations available. The conversation emphasizes the importance of correctly setting up the equations to solve for the system's dynamics.
tonicandgin
m1 and m2 are connected by a massless string wrapped around a massless pulley. An external force F is applied to the pulley. m1 does not equal m2
find the acceleration of each mass, the tension in the string, and the acceleration of the pulley.
F external and m1 and m2 are known.
there is no gravity or friction in the problem.
F=ma
What I've worked out so far is that we must consider two reference frames to determine the accelerations. If we can calculate the acceleration of the pulley and the acceleration of one of the masses, the acceleration of the other mass should be determined.
If we consider the pulley's reference frame, one of the masses will be accelerating toward the pulley and the other mass will be accelerating with an equal and opposite acceleration.
If we consider m1, we see the pulley accelerating toward m1 and m2 accelerating with an equal acceleration.
how can we combine these two reference frames to determine the accelerations in the lab frame?
is the acceleration of the center of mass of the system relevant?
welcome to pf!
hi tonicandgin! welcome to pf! :wink:
tonicandgin said:
… we must consider two reference frames …
no :confused:
call the position of the pulley x, call the length of string between the pulley and m1 and m2, respectively, L1 and L2
and use the fact that L1 + L2 must be constant …
what do you get? :smile:
thanks for the response.
to clarify: what do you mean by "call the position of the pulley x"? is that its position before the force is applied and everything starts moving? or does x change as the system moves?
what i have so far is:
call position of the pulley x. call the length between pulley and the 2 masses L1 and L2, respectively
then position of m1 = x - L1 + 1/2 am1t2
and position of m2 = x - L2 + 1/2 am2t2
i've done a bunch of algebra trying to make use of L1 + L2 = L but nothing seems useful.
I think what i should do is write position equations for each mass and then take two time derivatives to get acceleration, but the only position equations i can write include the accelerations I'm looking for in the first place.
hi tonicandgin! :smile:
(just got up :zzz: …)
tonicandgin said:
… does x change as the system moves?
yes, that's the easiest way …
then you get …
then call the tension T, and do F = ma for each mass separately …
thanks for the help. so far I have:
a1 - ar = ap
a2 + ar = ap
where ar is the relative acceleration of each mass with the pulley.
( m1x1 + m2x2 ) / ( m1 + m2 ) is the center of mass of the system. if we take two time derivatives we get ( m1a1 + m2a2 ) / ( m1 + m2 ) which must equal the only external force, F.
F must = 2T
this is as much as i could get out of my professor today, he seemed to think it was solvable from here, but i still feel like there are too many unknowns and not enough equations.
yes, there are two ways doing it
your can either start with F = ma for the centre of mass, as your professor suggests,
or you can just do F = ma for each of the three bodies separately
tonicandgin said:
… i still feel like there are too many unknowns and not enough equations.
whichever method you choose, write out all the equations you have, and we'll see :smile:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
