Solving Rigid Body Kinetics: Pulley Tension & Moment of Inertia
The discussion revolves around a problem in rigid body kinetics, specifically focusing on calculating the tension in a pulley system and determining the moment of inertia. Participants are exploring the relationships between linear and angular accelerations, forces, and torques in the context of the problem presented.
  • Mixed
  • Participants are discussing how to calculate tension in the pulley without given acceleration. There are attempts to relate linear acceleration to angular acceleration and to derive equations involving forces and moments of inertia. Questions arise about the correct point of rotation for the moment of inertia and the relationship between different accelerations in the system.
There is ongoing exploration of the problem with various equations being proposed. Some participants are providing guidance on how to relate different variables, while others express confusion about the setup and calculations. Multiple interpretations of the problem are being discussed, particularly regarding the moment of inertia and the relationship between linear and angular quantities.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. There is a focus on ensuring that the assumptions made about the system are valid, particularly regarding the tension and the moment of inertia.
smruthi92
hey guys, please see the attachment for the question.
i drew FBDs and everything. i want to know a few things tho. how do i calculate the tension in the pulley?
if they'd given me acceleration i could have used T-mg =ma. but they havent. also once the Tension is found, do i just find the moment of inertia around the centre of mass and then resolve forces?
thanks,
s.s
hi smruthi92! :smile:
call the acceleration a, and the angular acceleration of the rod α, then do F = ma and τ = Iα :wink:
hey tim,
i can't seem to find a to find the tension, that's my problem. :(
call it a, and you can eliminate it later …
what do you get? :smile:
im sorry i don't get it :(
using M = I alpha
I = mL^2/12
but that's all i understand. u know the tension, it produces a moment right? so using that i got:
M = I alpha
T = I alpha
ma +mg = I x alpha
smruthi92 said:
ma +mg = I x alpha
where does this come from? :confused:
you need separate equations (both involving T) for the mass and for the rod, and you also need an equation relating a to α
(oh, and your moment of inertia is about the wrong point)
try again! :smile:
try again! :smile:
sorry that's right.
I = mL^2/12 + md^2
a = alpha x r
M = I x alpha
M = T d
T = mg +ma.
but u know the a we find from a = alpha x r, is it the same a of the mass on the pulley?
yes, the string stays the same length, so a at one end of the string must be the same (well, minus) as a at the other end of the string :wink:
(and don't forget you must include the torque of the weight of the rod)
awesome! thank u so much, just one last question,. after finding the total torque at point A, how do u find the reaction force?
take components in the x and y directions and/or moments about the other end :wink:
ok thank u so much tim! uve helped me so much! :D
15K
  • · Replies 38 ·
  • · Replies 38 ·
  • · Replies 18 ·
