Solving Rotational Energy Problem | 1.6m Stick, .4-.070kg/m^2
The discussion revolves around solving a rotational energy problem involving a stick of varying mass density. The stick's density is defined as p = 0.4 kg/m - 0.070 kg/m² * x, with rotation occurring about one end. Participants debate the correct formulation for the moment of inertia, with disagreements on whether to use dV or δm = ρ*δr in the integral. The importance of accurately determining the radius R in the calculations is emphasized, as well as the need for correct integration limits. The conversation highlights the complexities of deriving rotational kinetic energy for non-uniform objects.
Jack86
I am having problems with a rotational energy problem.
It reads...
a think stick of length 1.6m is dense at one edn than at teh other: it's mass desity is p=.4kg/m-.070kg/m^2x, where x is the distance from the heavier end of teh stick. The stick rotates about an axis perpindicular to the heavier end with a period of 1.1s. Determine teh Rotational kinetic energy of teh stick.
I used K=1/2Iw^2. I found w by using the period. However, when I try to use the integral I=(integral)pR^2 dV, I cannot find R becuase it is not stated. How do I find R or is there another way around the problem?
R is the length of the stick.
And your integral is wrong. It should be I=(integral)pr² dr, not I=(integral)pR^2 dV,
I disagree: it should be dV (I can't think why it shouldn't, enlighten me :smile:).
(The distance from the rotational axis) R2 = x2 + y2. As the stick's thin: y,z \to 0.
R is the radius of the stick, I am sure of this. And the integral has to be with respect to volume, it's a 3d object
We have a stick rotating about one end. A small element δm at a distance r giving a small inertia δI = r²δm. Puting δm = ρ*δr and substituting gave me my final result. Hmm, how is it derived with dV, I'm not familiar with that ?
Fermat said:
δm = ρ*δr
I feel this should be:
δm = ρ*δV
Then again as the stick's thin, δm = ρ*δV basically reduces to δm = y*z*ρ*δr, where y and z are the thicknesses into different directions (I don't think you can jus cancel them out).
The attachement will take a while before it is approved (thus I cannot view it), maybe host the file on http://www.imageshack.us" ? (EDIT: You already did :smile:)
If you use your method to derive the I for a uniform thin rod, you will come up with (1/3)ρR3, which is wrong. Either of the methods I've mentioned should give the correct (1/3)MR2
EDIT: Lots and lots of edits :smile:, small typos of all kinds.
δm = ρ*δV
ρ is the linear density, in kg/m
The integral is still from 0 to 1.6 though right?
Yeah, I think we would both agree on that :smile:
