Solving Simple Limits with Examples
  • Thread starter Thread starter __redzone
    Limits
__redzone
I'm given the limit f(x + \Deltax) / \Deltax
Given f(x) is 2x + 3, do I just plug in 2x +3 into x? Or do I plug it into x and \Deltax, or do I find the limits of f(x + \Deltax) / \Deltax) and -f(x)/\Deltax?, etc..If someone could get me started on this it would be great, Thanks.
First of all, write your problem CORRECTLY from your book. That you haven't done.
This is my first time using latex so I guess I'll just type it out for clarity. Find the limit of the function (f(x + delta x) - f(x)) / delta x as delta x approaches 0 when f(x) = 2x + 3.
Quite so.
Given that, what is in this case f(x+delta x)?
You are going to find it very, very difficult to do calculus if you don't understand what "f(x)" and "f(x+ y)" mean!
If f(x)= 2x+ 3, then f(a)= 2a+ 3 (just replace x in the entire formula with whatever is in the parentheses on the left). In particular, f(x+ y)= 2(x+ y)+ 3= 2x+2y+ 3.
(Your latex was fine in your first post. arildno's point was that you didn't specify "as \Deltax goes to 0"!)
Actually, he did not subtract f(x) in the numerator; that's what I reacted upon.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
