Solving Tension Force: Angle & Magnitude
  • Thread starter Thread starter RedBurns
    Force
A ball hanging from a rearview mirror experiences tension in the string due to the car's acceleration. The car accelerates at 1.0 m/s², and the ball's mass is 4 kg, leading to equations for horizontal and vertical forces. The weight of the ball is calculated as 39.2 N, and the total force considering acceleration is 43.2 N. To find the tension, the equations T sin(theta) = m a and T cos(theta) = mg can be used, with the suggestion to divide one by the other to simplify. Visualizing the forces as a triangle can help determine the angle theta.
RedBurns
A ball hangs from a string on the rear view mirror of a car. The car is accelerating, causing the string to be at an angle theta with the vertical. If the car is accelerating at 1.0m/s2 and the mass of the ball is 4kg, what is the magnitude of the tension on the string, and at what angle is it?
Fx) -T* Sin (theta) = MA
Fy) T*Cos(theta) -w=0
MA= 4 * 9.8 = 39.2
W= 39.2 + (4 * 1.0)= 43.2
Fx) -T * Sin (theta)= 39.2
Fy) T * Cos (Theta) -43.2 = 0
Fy) T * Cos (Theta) = 43.2
Could somone point me in the right direction for the next step in finding T? I'm not very strong in math and I'm not sure were to go from here.
At this point, you're doing fine. I'm not sure what you were doing after that.
Rewrite your equations like this:
T \sin\theta = m a
T \cos\theta = w = mg
To solve these two equations, try dividing one by the other. See what happens.
acceleration a = 1.0 m/s/s ...
This "a" has ALMOST NOTHING to do with "g" = 9.8 N/kg !
the weight = Force by gravity = mg , = T cos(theta) .
T sin(theta) = m a .
Try drawing a triangle of these components, and see what tan(theta) is ...
Thanks! Thats what I needed.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
