Solving the P-V Diagram Ratio of p2/p1
The discussion focuses on calculating the ratio p2/p1 from a p-V diagram involving two paths for a gas transitioning from state a to state b. Path 1 requires 3.0p1V1 of heat, while Path 2 requires 8.5p1V1. The attempt to solve the problem involves equating changes in internal energy for both paths, leading to the equation 8.5p1 = 3p2. The resulting ratio is p2/p1 = 8.5/3. The absence of a visible p-V diagram complicates the analysis.
aub
The p-V diagram in the figure below shows two paths along which a sample of gas can be taken from state a to state b, where Vb = 4.0V1. Path 1 requires that energy equal to 3.0p1V1 be transferred to the gas as heat. Path 2 requires that energy equal to 8.5p1V1 be transferred to the gas as heat. What is the ratio p2/p1?
http://edugen.wiley.com/edugen/courses/crs1650/art/qb/qu/c18/pict_18_96.gif
ΔE=change in internal energy=Q-W (=heat-work)
I tried to work this way but it's wrong..
ΔE2=ΔE1
8.5p1v1 - 3v1*(p2-p1)/2 (<--area inside the triangle)= 3p1v1
8.5p1v1 - 3p2v1 + 3p1v1 = 3p1v1
8.5p1 = 3p2
p2/p1=8.5/3
There is no pV diagram that we can see.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
