Solving the Polynomial: Tips and Tricks for Finding Solutions
  • Thread starter nirvana1990
  • Tags
    Polynomial
In summary, the author tried to solve an equation by dividing by x^2 and found that x+1/x was a factor. He then tried to factor the equation using the rational root theorem but got stuck. He then tried to solve the equation using the Descartes rule of signs and found that v^2-2v=0.
nirvana1990
46
1. Solve the eqution: x^4-2x^3-6x^2-2x+1=0
2. Homework Equations
Hint: let v=x+1/x
3. The Attempt at a Solution
Well, I didvided by x^2:
x^2-2x-6-2/x+1/x^2=0
since v=x+1/x, -2x-2/x=-2v
So now I have: 2v=x^2-2x-6 but I really don't know what to do with this, I tried rearranging to find x in terms of v to substitute back into the original equation but that got quite complicated and messy!
The back of the book says the solutions are: -1,2+3^0.5, 2-3^0.5
Don't divide with [itex]x^2[/tex]. Try to guess a solution (test 0, 1, -1 etc.) and then perform polynomial division (if you know how).
erm ok thanks-so am I trying to divide it so I get x+1/x ? How do I figure out what to divide by?
Divide until you get a quadratic. Try inputing easy numbers like -1,0,1 into the equation and if it equals 0 then it is a factor. In this quartic (x+1) ends up being a factor twice (I got a different answer from the book.) So that means that -1 is a factor. Then use Synthetic Division (Which in my opinion is much easier and will produce less mistakes than polynomial division) and keep on trying until you get down to a quadratic and just do the quadratic formula. (-b +- sqrt(b^2 - 4ac) / 2a)
What shall I divide by to get a quadratic? I've tried dividing by x, x^2 and x^3
i m tryin this way:
(Ax^2+Bx+C)(Dx^2+Ex+F)=x^4-2x^3-6x^2-2x+1
seems like an elegant eq~!
I'm now trying to factorise the quartic into two quadratics like rootX says to do but how are we supposed to know what goes into the 1st bracket? Do we have to find the factors using the synthetic division (do we just guess at what could be a factor and see if there is no remainder?)
if [tex]v=x+\frac{1}{x}[/tex] consider what [tex]v^2[/tex] will be and from the equation you have to solve...factorise out [tex]x^2[/tex] from it and see what happens
That's not right. Didn't you mean
x^2 - 6 + 1/x^2 = 2v?
And since the whole point of a change of variable is to try and express everything in terms of v you should consider higher powers of v to see if you can do anything with them
ooh! I think I get it! Thanks for your help guys! I tried x=1 which gave a answer of 0 so that meant x+1 was a factor so then I used the polynomial division suggested by Moridin to cancel the quartic down then did the same again to get a quadratic and used the formula (thanks to SnipedYou) which gave the solutions.
Is there a way to find a factor to start off without "guessing"?
There's a problem... 1 is not a solution of
x^4 - 2x^3 - 6x^2 - 2x + 1=0​
Surely you've seen the rational root theorem, which tells you how to write down a short list of rational numbers, in which every rational root (if any) appears?
By the way, do you know why you got the hint to try
v = x + 1/x?​
And do you know what would lead someone to think about trying that?
Hint for Hurkyl's question: symmetry.
Uses Des Cartes Rule of Signs and then use the Rational Root Theorm
Or USE THE HINT GIVEN !
Divide both sides, as you say you did, by x^2:
x^2- 2x- 6- 2/x+ 1/x^2= 0
If v= x+ 1/x then v^2= x^2+ 2+ 1/x^2.
Isn't it obvious to write the equation as
(x^2+ 2+ 1/x^2)- 2(x+1/x)- 8= 0
v^2- 2v- 8= 0. That factors easily.
Oops sorry! I meant I'd used x=-1 not x=1. I've never heard of the rational root theorem but I'll look it up now. I get how to use the hint they've given now- thanks!
1. What is a polynomial?
A polynomial is a mathematical expression consisting of variables and coefficients, combined using operations of addition, subtraction, and multiplication. It can also contain powers and exponents, but not division by a variable.
2. How do you solve a polynomial?
To solve a polynomial, you need to find the values of the variables that make the expression equal to zero. This can be done by factoring, using the quadratic formula, or by graphing the polynomial and finding the intercepts.
3. What is the degree of a polynomial?
The degree of a polynomial is the highest exponent of the variable in the expression. For example, the degree of the polynomial 3x^2 + 4x + 1 is 2, because the exponent of x is 2.
4. Can all polynomials be solved?
Yes, all polynomials can be solved. However, the method of solving may vary depending on the degree and complexity of the polynomial. Some polynomials may require advanced techniques such as synthetic division or the use of complex numbers.
5. What is the significance of solving polynomials?
Solving polynomials is important in many fields of science and mathematics. It allows us to find the roots or zeros of an equation, which can provide insight into the behavior of a system. It is also used in optimization problems, modeling real-world situations, and understanding the relationship between variables.
