[Something descriptive here will yield more responses]
  • Thread starter Thread starter tanzl
    Yield
The discussion centers on calculating the force exerted by the tabletop on an incline with a block sliding on it. The initial assumption that the force is simply (M+m)g is questioned, as it seems overly simplistic. Participants emphasize the need to consider the normal force acting on the block and the reaction forces involved due to the incline's motion. A free-body diagram is recommended to visualize all forces acting on the incline, ensuring the net force remains zero. Understanding these dynamics is crucial for accurately determining the tabletop's force throughout the block's motion.
tanzl
In the flgure below, the incline has mass M and is fastened to the stationary horizontal tabletop. The block of mass m is placed near the bottom of the incline and is released with a quick push that sets it sliding upward. It stops near the top of the incline, as shown in the flgure, and then slides down again, always without friction. Find the force that the tabletop exerts on the incline throughout this motion.
My answer is (M+m)g. But, it looks too simple to be correct.
Please clear my doubts.
1)Although there is a normal force of magnitude mg*cos(theta) that will eventually balance the weight of the mass m since the mass is not moving downward o upward.
2)The initial push on the mass m is not necessary to be considered in the calculation because the force supplied is not constant and so the only force acting on mass m which parallel to the incline is mg*sin(theta).
The picture hasn't come up yet, but your description points to something you need to consider. The normal force provided by the incline against the block is not vertical; thus, the "reaction force" of the block against the incline is not vertical. The table must in turn exert forces against the weight of the incline and block and this "reaction" force. Make a free-body diagram showing all the forces acting on the incline from both the block and the table. What must the forces from the table be in order that the net force on the incline comes to zero?
