Sound frequency and strength measuring
Vanjlaz
Can you please help me with my problem?
I need to measure how sound spreads trough foam. To measure it i need one source of sound and one recorder of sound. Ofcourse i need to change frequency and strength of sound to see if there is change in its spreading trough foam.
I don't know how to produce and measure sound of specific frequency and strength? I have some ideas of my own but I am not sure if they would work.
First i have to produce sound. Is there an instrument that produces different kinds of sound and shows their frequency and strength? Perhaps a computer program?
I could use some kind of musical instrument to produce sound but then I would have to measure its frequency and strength and it would not be so precise.
How to measure frequency and strength of sound:
First idea:
Could I use microphones connected to computer? What software would I have to get then? Would it be precise? :rolleyes:
Second idea:
Could I get some kind of instrument which meashures it?
Please help.
1. To produce the sound, you need a speaker, which you can hook up to a function generator (which can be used to change waveform and well as frequency).
2. To measure the sound, you could use either a microphone (if you are measuring it in air) or an accelerometer (if you want to measure the sound waves inside some solid/liquid medium). You'd probably want to feed your output from the recording device through an amplifier, before feeding it to an oscilloscope (or, if you want to get fancy, a spectrum analyzer).
Thank you very much!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
