Sound Insulation Testing Standards - Advice Needed
In summary, the conversation is about seeking advice on where to perform sound insulation testing for plastic foam/cellular products according to EN/ISO/ASTM standards. The recommended tests for this purpose are E90, E336, E596, and E1414. The person seeking advice is advised to contact an accredited test facility or their National Measurement Institute, such as the Vietnam Metrology Institute.
Khoa
Dear All,
I'm seeking for EN/ISO/ASTM standards and where we can perform sound insulation testing for plastic foam/cellular products. Can you give me an advice?
Thank in advance,
Khoa
C634 Terminology Relating to Building and Environmental Acoustics
E90 Test Method for Laboratory Measurement of Airborne Sound Transmission Loss of Building Partitions and Elements
E336 Test Method for Measurement of Airborne Sound Attenuation between Rooms in Buildings
E596 Test Method for Laboratory Measurement of Noise Reduction of Sound-Isolating Enclosures
E1414 Test Method for Airborne Sound Attenuation Between Rooms Sharing a Common Ceiling Plenum
Dear Dipstik,
Thank you for your kind supprot,
Do you know where can perform this test?
Where are you based? You need an accredited test facility (in for example the UK that would be a company with UKAS accreditation for the relevant test)
You can always try contacting you National Measurement Institute, they should have list of accredited companies that can perform the test you need.
Edit: according to your profile you are based in Vietnam; so try the Vietnam Metrology Institute.
1. What are sound insulation testing standards?
Sound insulation testing standards are a set of guidelines that specify the requirements for testing the sound insulation performance of a building's walls, floors, and ceilings. These standards are used to evaluate the effectiveness of a building's sound insulation and ensure it meets the minimum requirements for noise control.
2. Why is sound insulation testing important?
Sound insulation testing is important because it ensures that a building's noise levels are within the acceptable range and that the occupants are protected from excessive noise. It also helps to identify any weaknesses in a building's sound insulation, allowing for improvements to be made and potential noise complaints to be avoided.
3. What are the different types of sound insulation testing standards?
There are two main types of sound insulation testing standards: airborne sound insulation and impact sound insulation. Airborne sound insulation measures the sound transmission through the air, while impact sound insulation measures the sound transmission through the structure, such as footsteps or objects dropping on the floor.
4. How is sound insulation testing performed?
Sound insulation testing is typically performed by a trained acoustics specialist using specialized equipment. The test involves creating a controlled noise source in one room and measuring the sound levels in both the source room and the receiving room. The difference in sound levels between the two rooms determines the sound insulation performance.
5. What factors can affect the results of sound insulation testing?
There are several factors that can affect the results of sound insulation testing, including the construction materials used, the building design, and the installation of sound insulation. Other factors such as background noise and weather conditions can also impact the accuracy of the test results.
  • Materials and Chemical Engineering
  • Electrical Engineering
