Sound velocity in a moving fluid
Sound velocity in a stationary fluid is the same as in a moving fluid when measured relative to the fluid itself. Ultrasonic flow meters use sound waves to determine fluid flow rates, employing either transit-time or Doppler methods. The transit-time method measures the difference in sound speed between upstream and downstream transducers to calculate fluid velocity, while the Doppler method relies on frequency shifts caused by particles in the fluid. Both methods have advantages, such as unobstructed flow and minimal sensitivity to pipe diameter, but their performance can be affected by flow conditions. Understanding these principles is essential for accurate fluid flow measurement in various applications.
masoud2001
what's difference of sound velocity in a stationary fluid compared to a moving fluid?
regards
No difference at all if you are measuring relative to the fluid.
“Ultrasonic flow meters utilize sound waves to determine the flow rate of fluids. Pulses from a piezoelectric transducer travel through a moving fluid at the speed of sound and provide an indication of fluid velocity. Two different methods are currently employed to establish this velocity measurement; transit-time and Doppler methods.
Ultrasonic meters have several advantages, including freedom from obstructions in the pipe and negligible cost sensitivity with respect to pipe diameter. However, their performance is sensitive to flow conditions.
Transit-Time
The transit-time method uses two opposing transducers which are mounted at a 45 degree angle to the direction of flow. The speed of sound from the upstream transducer to the downstream transducer represent the inherent speed of sound plus a contribution from the fluid velocity. A simultaneous measurement is taken in the opposite direction which represents the speed of sound minus the fluid velocity. The difference between these two values is representative of the fluid velocity which is linearly proportional to the flow rate.
This method works well where the fluid is free of entrained gas or solids which can scatter the sound waves traveling between the transducers.
Doppler
This type of ultrasonic meter uses two transducers mounted in the same case on one side of the pipe. An ultrasonic sound wave of constant frequency is transmitted into the fluid by one transducer. Solids or bubbles within the fluid reflect the sound back to the receiver element. The Doppler principle states that there will be a shift in apparent frequency or wavelength when there is relative motion between transmitter and receiver. Within the Doppler flow meter, the relative motion of the reflecting bodies suspended within the fluid tends to compress the sound into shorter wave length (high frequency). This new frequency measured at the receiving element is electronically compared with the transmitted frequency to provide a frequency difference which is directly proportional to the flow velocity in the pipe. In contrast to the transit-time method, Doppler ultrasonic meters required entrained gases or suspended solids within the flow to function correctly.”
http://www.sulphuric-acid.com/techmanual/Instrumentation/instr_flow.htm
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
