What is the largest wavelength for maximum sound intensity?
To determine the largest wavelength for maximum sound intensity at an observation point from two sources, the equation |d1 - d2| = n * (wavelength) is used, where n represents the order of constructive interference. For source A at distance d and source B at 3.7λ, the goal is to find the largest wavelength in terms of d. When d is given as 14.1 m and the speed of sound is 340 m/s, the frequency can be calculated using the relationship between speed, frequency, and wavelength. The discussion highlights the importance of constructive interference in achieving maximum sound intensity. Understanding these principles is crucial for solving the problem effectively.
mert123
Two sources, A and B, emit a sound of a certain wavelength. The sound emitted from both sources is detected at a point away from the sources. The sound from souce A is a distance d from the observation point, whereas the sound from source B has to travel a distance of 3.7λ. Take v to be 340 m/s.
a) What is the largest value of the wavelength, in terms of d, for the maximum sound intensity to be detected at the observation point?
b) If d = 14.1 m and the speed of sound is 340 m/s, what is the frequency of the emitted sound?
How you have attempted at the solution?
I have attempted at the solution by using the equation |d1-d2|= n*(Wavelength) n=0,1,2... ,which is the equation constructive interference of waves.
However, i am not sure that i'll going to use this formula for the maximum sound intensity
