What factors can affect the efficiency of soxhlet extraction?
  • Thread starter Thread starter Patty
    Cycle Extraction
The discussion centers around issues with the Soxhlet extraction cycle, specifically the failure of liquid in the middle section to return to the bottom section despite reaching the appropriate height. Key points include the potential influence of temperature on solvent volume and viscosity during the extraction process. Variations in these factors could affect the overall efficiency and outcomes of the Soxhlet extraction. The conversation highlights the importance of considering these variables when troubleshooting extraction procedures.
Patty
I have a trouble with soxhlet extraction cycle.
Liquid in the middle section of soxhlet appratus should returen to the bottom section of soxhlet appratus when it reaches an appropriate height. The question is :The return did not appearence in the whole cycle but the liquid level actually reached that height.
Chemistry news on Phys.org
Did the solvent volume change?
soxhelt extraction procedure?Why?
march.12.2004
Is your procedure temperature dependent for extraction,if so volume at that temperature would had been altered.Also the viscosity must be altered.I do not actually know your specific experiment but being a physical chemis i guess possible variables which might affect experimental outcopmes.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
