Special Relativity and time dilation
The discussion centers on calculating the time dilation effect experienced by two spaceships traveling at a relative velocity of 1.2x10^8 m/s, utilizing the Lorentz Factor formula. Participants confirm that the clocks on each ship will disagree by a factor of approximately 1.291, indicating that each captain perceives the other's clock as ticking more slowly. The factor is dimensionless, as it represents a ratio of two time intervals. Participants emphasize the importance of correctly applying the Lorentz Factor in special relativity calculations.
  • Understanding of special relativity concepts
  • Familiarity with the Lorentz Factor formula
  • Basic knowledge of relative velocity
  • Ability to perform algebraic calculations
  • Study the derivation of the Lorentz Factor in detail
  • Explore examples of time dilation in various frames of reference
  • Learn about the implications of time dilation in GPS technology
  • Investigate the effects of relativistic speeds on mass and energy
Students of physics, educators teaching special relativity, and anyone interested in the practical applications of time dilation in modern technology.
mikil100
Two spaceships are traveling with a relative velocity of 1.2x10^8 m/s, both carrying clocks.
According to the captain of each ship, the other captains clock ticks more slowly than his own. By what factor do the clocks disagree?
1/(1-(v^2/c^2))^1/2
The only formula I can think of that brings up the time dilation going on is the Lorenz Factor, as the only given value is the relative velocity of each ship. I interpreted this question as the ships are speeding at a little over 1/3 of the speed of light past each other if they are using each other as a frame of reference, So I simply plugged the velocity (which is relative to each captain, using the other ship as a reference frame) into the equation to get... so the clocks disagree by a factor of 1.291... I am not sure what units I would even place there or if it is just a number with no units.
Is this the correct line of thinking?
Yes, you are right on track and the factor has no units because it is a ratio of two times.
I get a different number for the answer. I'm old and out of practise so you are probably correct, but do run it through again to check.
  • · Replies 67 ·
  • · Replies 21 ·
  • · Replies 25 ·
