Special Relativity, please explain the meaning of this problem
The discussion centers on a problem from "Problems in General Physics - I. E. Irodov" regarding special relativity, specifically problem 1.355. The task is to determine the displacement velocity (v) of a point in reference frame K, where the clock readings of both K and K' are identical. The conclusion reached is that v must be less than the relative velocity V between the two frames, and the formula for v is given as v = (1 - (1 - (V/c)2)1/2)c2/V.
  • Understanding of special relativity concepts, including reference frames.
  • Familiarity with the Lorentz transformation equations.
  • Knowledge of the speed of light (c) and its implications in relativity.
  • Basic algebra for manipulating equations and solving for variables.
  • Study the Lorentz transformation and its applications in special relativity.
  • Learn about time dilation and simultaneity in different reference frames.
  • Explore the implications of relative velocity in special relativity problems.
  • Review additional problems from "Problems in General Physics - I. E. Irodov" for practical applications.
Students of physics, particularly those studying special relativity, educators looking for problem-solving examples, and anyone interested in the mathematical foundations of relativistic physics.
shanu_bhaiya
The reference frame K' moves in the positive direction of the x-axis of the frame K with a relative velocity V. Suppose that at the moment when the origins of coordinates O and O' coincide, the clock readings at these points are equal to zero in both frames. Find the displacement velocity v of the point (in the frame K) at which the readings of the clocks of both reference frames will be permanently identical. Demonstrate that v<V.
The meaning of the problem
Ok, the problem is that I don't understand the meaning of the problem. Does it mean to find the velocity of a point (v) such that the clocks infront of each other in that point's frame show same time, but that seems me impossible, if not then what the problem may mean.
I only want to know the meaning of the problem, please don't solve it.
Reference
Problem is 1.355 from "Problems in General Physics - I. E. Irodov". And answer is v = (1-(1-(V/c)2)1/2)c2/V
I think it means that you need to find the speed of an observer, relative to K, at which the observer would calculate the clock rates in K and K' to be the same.
Yup, thnx turin, that is what it meant.
  • · Replies 33 ·
  • · Replies 20 ·
