Special Relativity question - SHOULD be easy
The discussion revolves around a problem in special relativity involving two events with specific space and time coordinates. The goal is to demonstrate that there exists an inertial frame where these events occur simultaneously and to determine the relative velocity of this frame. The user attempts to apply the Lorentz transformations but encounters a sign error leading to an incorrect conclusion about the velocity. The correct approach involves careful manipulation of the equations, particularly when substituting for simultaneous events. Clarification is sought on the transition between equations, highlighting the importance of correctly handling signs in the calculations.
joker_900
The space and time coordinates of two events as measured in a frame S are as follows:
Event 1: x1 = x0, t1=x0/c
Event 2: x2 = 2x0, t2=x0/2c
Show that there exists an inertial frame in which these events occur at the same time, and find the velocity of this frame relative to S.
Lorentz Transformations
dx = k(dx' + vdt') and dt = k(dt' + vdx'/c^2)
(I'm writing delta as d and gamma as k as I can't do the symbols here)
Now I'm pretty sure that the v is the velocity of frame S' relative to S?
So I used these equations, and made the second one
c^2dt/v = k(c^2dt'/v + x')
Subtracting the first equation from this gives:
c^2dt/v - dx = kc^2dt'/v + kdx' - kdx' - kvdt'
But if the two events are simultaneous in S', then dt'=0.
so c/2v = 1
v/c = 0.5
beta = 0.5
Unfortunately the answer is -0.5, which is important later in the question, and I cannot work out why. I'm sure the equations are right, and surely the v in that is the velocity of S' relative to S, which is what I'm after here?
Thanks!
Please show exactly how you got from:
to:
so c/2v = 1
you're making a mistake with signs or something here... in this step.
